f2b question
Old May 5, 2010 | 02:52 AM
speedfreak44's Avatar
Default f2b question
hey guys, my car is an jdm eg9 and has b16a with a manual trans. i got my f20b sir from a cf4 sir accord last month and i am now ready to swap in.
So here are my questions.
Which H2B kit i should use to give me a good sub rail clearance? What i noticed is that the f20b has a single belt crank pulley where as the h22 has a double so i think it will have a better clearance. Not so?
Also the right side axle will be reused , but what about the left side? which intermediate shaft will i have to used the f20b or the b16a?
I heard some guys saying that i could use the f20 shaft but remove the remove the cup and replace it with the b series and use the b series left side axle... is the true?
Old May 5, 2010 | 11:45 AM
Default Re: f2b question
anyone?
Old May 7, 2010 | 12:55 AM
spoolin94ls's Avatar
u jus use the b series axles not the f series.
Old May 7, 2010 | 03:53 AM
flatblack-h22's Avatar
use your b16 int. shaft and axles.
QSD all the way
Old May 7, 2010 | 02:20 PM
nice... cool
would i have any block rubbing issues with the b16 int shaft
Old May 9, 2010 | 06:57 PM
DSRxCandyh2bEG's Avatar
you would have to grind down the back of the block to make clearance for the b series half shaft and axle....
bokals
Jul 8, 2008 12:30 PM
TallKyle
Mar 24, 2005 10:10 AM
USDM 4G VTEC
15
Apr 15, 2003 05:54 AM
