00 civic swap questionj please help
i am looking into swaping out my motor in my 00 civic and i am looking at swapping in my buddies b18b or looking for another b series swap for it and i need to what is compatible and whats not and will my wiring harness work with it? thank you i need to know asap.
Re: 00 civic swap questionj please help
Well, Your civic is OBD2b and your motor is OBD2a. How complete is the swap? You got a ECU, axles, motor and tranny? You will need Civic Si (99-00) front tranny mount, rear T bracket and front lower engine bracket. You can re-use your driver side upper setup. Or buy hasport or equivelent. Not sure if your IACV is gonna be 2 or 3 wire. easy fix if its 2 and the civic is 3 (you will need a 2 wire harness plug for this). You may need to do some modification to the exhaust depending on what manifold you use.
You need Bseries shift linkage. Tools, a brain and a lift.
I would just get or trade to get a 96-97 LS ECU. OBD2B is different then OBD2a. or get the jumper harness to convert 2a to 2b. not sure if LS has a CFK by the crank? if it does your civic plug will have to be swapped with a integra plug on your harness end.
Be sure to get the plugs you need and dont hardwire stuff. Too much headache don the road. any tuning shop should have lots of everything you need and if they are cool like my guys, They will be happy to give you tips also.
May have forgot somethin, if I did someone will be sure to let you know.
Nick
Nick
hey thanks for the help and its not a complete swap i need to half shaft and the ecu as fas as the wiring goes im gonna get an ecu harness jumper to convert it from a 2b to a 2a so i can a p75 ecu and i also need a distributer adapter to turn the dizzy from a 10 pin to a 8 pin which both i found on rywire.com for the exhaust im not exactly sure on what to do i heard to just get the header for the ls and the cat back for the car but i was thinking about getting the cat back for an si instead since it has the b series in it but for the cat im not sure tho.
no i havent yet i was waiting til i got paid again at work which is next week should i get stock mounts or aftermarket? my friend priced out all the mounts for me from honda and they are a little more exspensive than hasport and the cat is same length as what an si or an ls?
If you're looking for mounts man, holler at me. Check the link in my sig if you want to check em out. Brand new company MPC Motorsport. Cheaper than Hasport, better machining quality, and lifetime warranty for original owner, no questions asked.
Oh look, Spencer is selling DIRECT copies of Hasport mounts.. Looks to me like another guy selling mounts that will be gone next year, good luck on getting a lifetime warranty.. Tell you what, I'll be happy to find you a dealer that will get you better pricing on genuine Hasport mounts, and Hasport will still be here if you ever do need any help, as they have already been around for at least 12+ years. Don't support guys who just copy other peoples work, or do they just buy the Hasport mounts, mill the Hasport logo off, put their logo on, and brush finish the mounts and claim them as their own? Even the toolpaths look the same..
mr devious illusions
07-22-2006 10:56 PM
pr_tony_montana
02-03-2005 05:13 AM
