NEED HELP ASAP! HORRIBLE GAS MILEAGE IN K20Z1 SWAPPED EJ8
So I have a Z1 in my 99 EJ8, recently got it tuned after I got it through a trade and the gas mileage is HORRIBLE. I am barely getting 100 Miles to the TANK! IS this normal? Took it back to my shop and the tuner connected it to KPRO and the A/F ratio was perfect. I am running on the stock injectors as well as the stock fuel pump, could this be the reason? Any other DD swapped K drivers please put your input on how your MPG or how much you get to the tank. Thanks for the help.
Re: NEED HELP ASAP! HORRIBLE GAS MILEAGE IN K20Z1 SWAPPED EJ8
your asking if 100 miles to one tank is normal come on take your head out of your *** if that was the case no one would buy any of the new civics
I don't need a smart *** comment, just one explaining why a car with a perfect A/F ratio and tune is getting 100 miles to the tank. Thanks.
it might help if you post what the a/f ratio is , i wouldnt have to post a smart *** comment if you didnt ask dumb question and there are such things as a dumb question even if your mom told you otherwise
low430
10-02-2005 01:53 PM
