H22 with euro R tranny T2T4
i just bought a H22A and ill buy a Euro R transmission (T2T4) soon, wonder if it really fits, the relation its good for use it in a....CRX.
Re: H22 with euro R tranny T2T4
yeah im sorry you are right, it fits on he H22, right? i think i have 2 more options to get a Transmission the f20 its blue cover and i think theres a red valve cover
this ratio will give good results in the crx?
Yes... both are similar gears. Euro R may have slight better 3rd and 4th and believe 3rd in T2T4 F20B little shorter then typical H22
Better transmission to not:
T2W4
T2T4
M2B4 JDM H22
All have LSD
T2W4
T2T4
M2B4 JDM H22
All have LSD
any f-series tranny will fit blue top or red top should be for f20b euro-r/type-r it'll fit it'll have a lsd and tight gear set up pm me let me know how it goes
Well friends, ill let all of you know how things go, let me see if i post pictures of the progress and steps. and also ask for advice and suggestions.
It took me lots of time to get it done....work its killing me...anyways, the car its really fast for having kinda nothing (mugen header, fpr, lightened original flywheel) the car feels really good, even when i shift from 3rd to 4th the car only losses less then a 1k rpm, but now its like the clutch its sliding to much on the flywheel it started to feel when i shifted to 4th gear and now its happening at lower gear change.
My mechanic don't want me to use a 4 leg bronze clutch because some differential damage that i might cause. but its a real good improvement.
His suggestion its to use some kind of sport clutch.
At the end i think that some oil have fall into the transmission when doing some fix on the vtec.
