New pix of Earthing system installed.
feel a difference?
btw, how long have you had the T1R battery? good/bad experience w/ it? do you recommend it?
[Modified by SilverCIVIC96, 1:41 AM 3/20/2003]
Smoother idle was noticeble. I can't speak much for throttle response since i have no ac, powersteering, and a JUN ultralight flywheel so if there were throttle improvements, i won't be able to tell. over all the engine feels smoother and so far these two days after it was installed the gas milage seems a little better.
T1R battery is xactly 14.8lbs it definetly is a good weight reduction method while getting to own a dry cell battery.
kind of hard to route it cleaner when you are trying to avoid hot metal and still route to the battery ground.
ok i still dont know
what the **** is an earthing system and what does it doread the improt mags. Its someone grounds the motor better and gives you HP.
sorry i only read grassroots motorsports.
Kamin,
It won't give you any added HP. Don't buy into that crap. It simply won't. Perhaps .5 hp?
The real benefit that I can personally attest to are:
-Improved gas milage
-Smoother idling
-Car starts smoothly and quickly.
-slightly more smoother linear acceleration.
-slight more throttle response.
-Smoother idling
Earthing=Grounding
it's basically just replacing/rerouting all your grounds. There are different methods; some chain all the grounds together, some redirect all your grounds to the neg. batt terminal (bad idea), some just replace the factory ground wires w/ bigger gauge wire.
It's a good cheap mod that's fairly easy to do. I like those...
E-Bay has got them......
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6770
[Modified by Rex_Dragon, 4:47 PM 3/20/2003]
[Modified by Rex_Dragon, 4:49 PM 3/20/2003]
[Modified by Rex_Dragon, 4:50 PM 3/20/2003]
[Modified by Rex_Dragon, 4:52 PM 3/20/2003]
Kamin,
-Smoother idling
-Smoother idling
Dyno charts that I saw shows .5whp to 3whp, but that doesn't really tell you its the earthing system. Doing dyno runs back to back you can get + or - 3whp with nothing else changed. Again, for the sake of not getting into a argument on the power it makes, the $ or effort you spend on this thing is for smoother engine performance over all, not power.
I think its a good buy for only $100. You should make sure to run them in a daisy chain to get good results. Also, if you have access to a dyno, try different grounding points like by the starter. Remember guys, it snot about peak horsepower, its how much useable horsepower you have.
Here is a new pic of my setup with the stock two Ground wires replaced with "Monster Cable" brand cable and Monster Cable 24K plated O ring.
Heres a funny question...I get the living crap shocked out of me all the time whenever I get out of a car, walking across the floor whatever.
My friends and family think its kinda weird. I actually used to have to replace my watch every year or so becuase of it.
Yeah I am a freak I reckon
Does anyone know if I installed this on my car if perhaps that would help?
H23ludedude
Apr 24, 2003 08:59 AM
