Any 4th gen EFers with a jdm b16?(fuel line question)
i cant seem to find where the fuel line goes on the new engine... i know it must be something im overlooking but if someone can point it out it would help alot....
the one i took off the old engine (d15b2)was a oval shaped connector that went on the TB but i cant find the fuel line on the jdmb16a...
Re: Any 4th gen EFers with a jdm b16?(fuel line question) (paybac4223)
It goes to the fuel rail which sits on four injectors which are on the runners of the intake manifold. You bolt it up to the side with the 17mm nut on the end, which will be the same side as the distributor.
Luke G.
14
09-10-2009 06:07 PM
