what factory mounts do I need with HCP mounts?
I have a US spec B18C1 for my 1988 crx si
I have the EF-18 hcp mounts
what L bracket and driver side engine mount will I need for the swap?
thanks
thanks
Re: what factory mounts do I need with HCP mounts? (DOHCarp)
If you have the EF-18X kit (replacement mounts), then you need to get a 90-93 rear tranny bracket (L-shaped part) and change the cast iron bracket on the block on the driver side to the 90-93 Integra or 89-91 B16 in order to use the HCP mount in your EF chassis. For clearance on the radius rod, change the crank pulley to a 90-91 Integra pulley and it'll clear the radius rod. With all of that done, the car will sit fine and have plenty of clearance all around, and it won't hit your hood either.
Re: what factory mounts do I need with HCP mounts? (Newman)
will it hit the radious rod if I use the stock pulley
Freeltec
19
05-13-2006 11:22 AM
Freeltec
05-12-2006 09:50 PM
