B18b mounts into EK
B18b mounts into EK
I got my motor, and All that came with it was 2 driver side mounts (one up high, one down low), 1 passenger side mount, and a rear mount. This engine is going into my 98 coupe. I was told I need 99si mount for driver side (do I need for top or bottom mount?), and for rear. Now do I need the mounts or the bracket for the rear? And is it correct that the Driver side mount will be a water mount? What do all the mounts look like, does anyone have pics of all the mounts? I didnt see the front mount....pics?
Re: B18b mounts into EK (civcexcoupeblack)
You will need:
1)99-00 Si Timing Belt Mount bracket...this connects to the block where the timing belt is and has vertical studs that connect to another bracket which bolts to the rubber mount on the driver's side.
2)99-00 Si Rear transmission bracket. This bolts in behind and underneath the intake manifold and connects the block to the rear rubber mount.
3)Any b-series front transmission bracket. This bolts to the front of the transmission and connects to the rubber mount which bolts underneath the frame rail.
Reuse all civic studs and rubber mounts. You only need those brackets! I know because some friends and I just swapped a B20Z into my '96 EK. If your engine was a B20Z there is a chance that the stock timing belt mount bracket on it will work...ours did! (Looked almost identical to the 99-00 timing belt bracket)..but since your engine is a B18B, you'll most likely need that Si bracket as well.
I can have pics whenever I get my car running...
1SlowSi
11-01-2008 05:42 AM
