replacing fuel pump
Old Mar 20, 2003 | 03:15 PM
mr.sleeper's Avatar
Banned
From: PUT BACK MY AVATAR YOU FUCKING FAG MODERATORS, canada
Default replacing fuel pump
my 98 cx hatch has a jdm itr motor. it runs fine but people tell me to replace the fuel pump to a DOHC unit instead of a SOHC non vtec pump. will i get any power gains from doing this or will my stock fuel pump be adequate enuff. welcome to all replies. thanx for the help
SPEC-R EK HATCH
Old Mar 20, 2003 | 03:21 PM
enhancedCL9's Avatar
Default Re: replacing fuel pump (mr.sleeper)
yeah i would like to know aLso?
Old Mar 20, 2003 | 05:46 PM
import palace's Avatar
an upgrade would be very nice. it will raise the fuel pressure in your rail also which allows for more power. if you are gonna do a fuel pump upgrade you might as well just go with a walbro 255 lph
Old Mar 21, 2003 | 03:24 AM
Default Re: replacing fuel pump (import palace perf)
But would it do any difference if i already have a AEM fuel pressure regulator?
Old Mar 21, 2003 | 04:08 AM
VTECVillain's Avatar
It's definitely a good idea to upgrade your fuel pump to a B series VTEC pump. A Walbro or other high flow pump isn't necessary but they will work if that's what you want to buy. Using the stock pump, you are running slightly lean on the high rpm's and even more if you have your timing advanced further than stock. Just get a B Series VTEC pump (Si, GSR, ITR).
Old Mar 21, 2003 | 01:35 PM
mr.sleeper's Avatar
Banned
Default Re: replacing fuel pump (VTECVillain)
*update*
i installed a walbro 255lph unit and i basically got a whiplash when vtec hit. thanx for the replies fellas!
SPEC-R EK HATCH
Old Mar 21, 2003 | 02:11 PM
irev210's Avatar
why does ur location say irev210 mr.sleeper lol
Old Mar 21, 2003 | 02:17 PM
mr.sleeper's Avatar
Banned
Default Re: replacing fuel pump (irev210)
because im in vtec all the time.
EJ8CIVIC
Jul 5, 2015 12:07 PM
integratypeRs
Dec 10, 2008 07:13 PM
86si
Jan 31, 2005 07:18 PM
85mm LsVTEC
Dec 22, 2003 10:19 AM
