ls distributor?????????
Old Mar 21, 2003 | 08:46 AM
dtyst's Avatar
Default ls distributor?????????
can i use use an ls distributor and ls fuel injectors on a gsr setup? what would be the down sides
Old Mar 21, 2003 | 11:05 AM
Scott - 93HB Si's Avatar
Default Re: ls distributor????????? (dtyst)
LS Fuel Injectors are the SAME as teh GSR ones.....same flow/size/etc
I want to say the LS Distrib won't bolt onto the gSR head, but i'm not 100% on that.
Old Mar 21, 2003 | 01:13 PM
Adriano's Avatar
Default Re: ls distributor????????? (Scott - 93HB Si)
it wont bolt-up, but you can modify it to. You have to modify one the wholes. The plugs are the same
civura R
Oct 4, 2002 02:58 PM
pregunta
Nov 9, 2001 09:49 AM
