B18C6 into JDM EG4 VTI... mounting points
The engine = 1998 UK ITR B18c6, the car = EG hatch Which had D15B sohc vtec. Are the mounting points the same?
[Modified by Redsun, 3:02 PM 3/22/2003]
Re: B18C6 into JDM EG4 VTI... mounting points (nsxmatt)
Are you sure? If they are the same then that's taken aload of my mind. Because i'm thinking of swapping at home with limited tools.
Re: B18C6 into JDM EG4 VTI... mounting points (Redsun)
I'm sure that your Civic and Integras are the same as we recieve here as far as mount positions so the steps for bolting in the engine would be the same as any other B-series swap into a USDM 92-95 Civic in which the motor bolts in with no cutting or welding.
Thank you very much for clearing that out for me. I've been getting alot people lately saying that modifications will have to be done to mounts...blah...blah...blah
Is the Civic a manual or automatic? If its auto, there will have to be some mount fabbing done to the chassis rail mount on the top of the transmission (driver's side for you, passenger side for us in the developped world).
Re: B18C6 into JDM EG4 VTI... mounting points (Jaker)
umm isnt the C6 a GSR engine?
damn crazy eurpoean motors.
but no matter what version of the b18c it is, its same mountling locations and using the b series mounts it will bolt in.
its a very easy swap.
Re: B18C6 into JDM EG4 VTI... mounting points (Kamin)
OK, thanx guys. I'm worried about the wiring also. I have the engine wiring and ecu side wiring harness. I take it i just splice it into my existing harness under the dash?
European Type R motor. I still dont exactly know what kinda specs these motors have?? Do people get them because they are rare or different??? I dunno i asked before but i didnt really get the answer i was looking for hehe.
Re: B18C6 into JDM EG4 VTI... mounting points (ZigenGSR)
when mounting a d to b series in a civic, don't you need to add a mount on the backside of the motor to the firewall? i think the d-series does not use this mount.
i don't know much so i would take my advice just yet.
anyone dis-agree?
anyone dis-agree?
Re: B18C6 into JDM EG4 VTI... mounting points (shepworldwide)
anyone dis-agree?
anyone dis-agree?
I hope this clears up a little bit, anyone else care to post incorrect information to continue to confuse the hell out of this guy?
(this applys as long as your car wasnt automatic)
As for the motor swap, It will be really easy, you have a couple options, you can rewire your obd2 ITR distributor to obd1 spec, or sell your distributor, and buy a dohc vtec obd1 distributor, use your old wiring harness, extend the few wires that dont reach the according sensors. Use the stock mounts that come with your ITR motor, use the linkage that comes with your ITR motor. You need an ECU, I would recommend a chipped p28 or any chipped DOHC obd-1 vtec program, or get a jumper that converts obd1 to obd2 plugs and use the ITR ecu, the ecu is basicly obd-1 so you wouldnt have to do much more then that. For axle setup, get 94+ integra axles w/ integra half-shaft, you should get all that with your swap.
Thats all i can think of atm, hope this helps.
[Modified by irev210, 6:01 PM 3/24/2003]
Re: B18C6 into JDM EG4 VTI... mounting points (irev210)
Yes I do, you dont attach anything to the firewall. You use the steering rack/subframe for the rear mount.
so i could just drop a b-series engine in place of my d-series. i was always told that you needed to buy an extra mount togo on the backside of the motor because the sohc d-series never used this mount.
sorry for sounding dumb but i'm really confused now
Jason913
29
12-27-2011 07:48 AM
JEM MotorSports
38
07-02-2006 08:08 AM
gsp ej1-em1
02-26-2006 06:52 AM
