Which ecu for b18c?
Old Mar 18, 2003 | 07:32 PM
EG6-SiR's Avatar
New User
Default Which ecu for b18c?
Quick query...
Which ecu tends to have the best results, out of p30 and p72?
Also, is an automatic b18c ecu of any practical use?
Also, as I am upgrading from a b16a, which mounts will i need to change?
[Modified by EG6-SiR, 4:33 AM 3/19/2003]
Old Mar 19, 2003 | 03:57 AM
VTECVillain's Avatar
Default Re: Which ecu for b18c? (EG6-SiR)
P72 with stock intake manifold, P30 with Skunk2 manifold
No, unless it's OBDI then you might be able to have it chipped.
If the motor is the same generation as the B16A and going in the same car you woun't have to change any mounts.
Old Mar 19, 2003 | 10:50 AM
EG6-SiR's Avatar
New User
Default Re: Which ecu for b18c? (VTECVillain)
What about the p30 on the b18 manifold if the secondaries have been removed?
Also, I'm going to need the b18c throttle cable if i use the b18 manifold right?
momodc221
Dec 14, 2011 10:18 PM
bsm123
Engine Management and Tuning
19
Jun 3, 2011 09:33 PM
speedyR
Feb 18, 2004 01:30 PM
freakie
Oct 17, 2003 10:13 PM
-CP-
Sep 30, 2002 09:02 AM
