Is GSR fuel pump direct replacement for Eg fule pump? Pics of GSR pump inside! 56k is ok!
The fuel pump came with my GSR swap and I'm wondering if I can install this in my Eg hatch (93 Cx)? Here are the pics of the fuel pump:
Thanks!
Thanks!
Re: Is GSR fuel pump direct replacement for Eg fule pump? Pics of GSR pump inside! 56k is ok! (Hybr
Yes you can use the GSR fuel pump. I have a 92 VX with a 99 B18C1 swap and I'm using the 99 GSR fuel pump. You will need to transfer just the pump with sock from the GSR onto the Civic housing
would that inapply to a 2k civic si fuel pump into a eg 92 ?
meaning i would have to just transfer the pump and sock
hondaeg8
11-16-2004 01:07 AM
