question about motor mount...
Old Mar 21, 2003 | 04:12 PM
MeanGreenEG9's Avatar
Default question about motor mount...
If I am putting in a b16a into a 96 civic coupe... I would retain the existing driver side uppper motor mount from the stock sohc motor correct? OR would I need to purchase the one made for the 99-00 civic si? A simple yes or no would do. Thanks.
Old Mar 21, 2003 | 04:30 PM
Default Re: question about motor mount... (B16aEJ)
bumpa
Old Mar 21, 2003 | 05:05 PM
VTECVillain's Avatar
You will need the driver's side motor mount bracket (what bolts to the block) from a 99-00 Civic Si then reuse your stock engine mount.
Old Mar 21, 2003 | 05:20 PM
Default Re: question about motor mount... (VTECVillain)
I guess I wasn't too clear.. I'm not talkin about the lower ac bracket torque mount. I'm talking about the upper driver side mount.. the one with the oil inside of it..
Old Mar 21, 2003 | 05:37 PM
So am I . I said you need the driver's side motor mount bracket from a 99-00 Si, meaning the upper one on the timing belt side that mounts to the block.
Old Mar 21, 2003 | 06:10 PM
THE GUY's Avatar
Not to be confused with "THE MAN"
you also need to use the entire rear motor mount from the 99-00 SI or the bolt holes wont line up did the same swap in a 96 in b16 pwrd ek car he also did what vtecvillian said and used the entire 96 driverside mount good luck with it the rear mount can be bought from honda for about 30-50 bucks
sorry I'm a retard
gsrjeff
Nov 22, 2008 11:44 PM
adamrich33
Nov 23, 2007 08:41 PM
GSaargh
Mar 18, 2007 02:27 PM
sleeperek
Jun 14, 2004 09:02 PM
