h22 eg running rough! please help!
so I finally got my hatch on the road. The car seems to be running ok, except for a really annoying problem. When I try to press on the gas pedal very lightly, at low speed and rpms - the way you might drive in a parking lot - the car yanks and jerks you back and forth violently. After a quick investigation, I found that with the car in neutral, if I press on the gas very lightly, the engine runs very rough, surging rhythmically like its misfiring or something, then when I give it a little more gas, it runs smoothly and well. Does anyone know what the crap is going on?
thanks for reading
Ok this only seems to happen between 1k-1.5k RPM. I unplugged the TPS and the problem disappears...but of course I couldnt rev past 2K RPM. sound like a busted TPS?
[Modified by dreamer, 7:05 PM 3/21/2003]
thanks for reading
Re: h22 eg running rough! please help! (hot_EG)
fuel filter? really. hmm, there shouldnt be anything wrong with mine, its only 30k miles old. yes Im getting CELs, but I dont know which ones
Im pretty sure capping off the EGR valve gives me a code...
Re: h22 eg running rough! please help! (dreamer)
i am experiencing the same. what ecu are you using? i am currently using a stock p30. i have a p72 but it seems to do it even more with it installed. i have no codes either. its a 98 h22.
Re: h22 eg running rough! please help! (delacampos)
****. Im using a stock p13.
what makes me really mad is I paid a mechanic $50 to fix my idle last week. he fixed the idle, but then this problem appeared. Proir to this I did all the work my self. on me for taking my car to a shop.
If you dont check your codes then it is going to be hard to diagnose the problem. I hate to see all these swaps being hastedly done without research but I know how it is when time and money is not on your side.
Do everyone a favor, check your codes first then and only then can I assist you in getting rid of the problem.
yeah, give me a hammer...moron
anyhoos, as said...find out the CEL code[s] for us.
Re: h22 eg running rough! please help! (hybrider93)
calm down, he was talking about himself...
whoa whoa that hammer was definitely for me. I think you might need to lighten up.
And I researched for months before doing this. Im sorry I dont have any way of checking what code Im getting in my home garage.
anyway I solved the problem on my own. everything smooth, no cels.
this site is becoming less about learning and helping people and more about flexing egos and trying to sound smart at other people's expense. even in the short time Ive been a member...
Re: h22 eg running rough! please help! (nsxmatt)
im having the same problem with my swap.... only code it throws is for my EGR wich is not connected...
check the vac hoses... spray some carb cleaner on them... if your idle goes up, you have a leak. I had a very simular problem.
Re: h22 eg running rough! please help! (LoudAccord)
got the problem solved on my car... switched out ecu's with my friend who also has the h22 swap and the car pulled like never befor.. and he has a stock ecu. mine was chipped by prospeed.. and for some reason it runs doggy.. can ya help me out brian?
