B18a swap into EG Question
To make a long story short, i am swaping a b18a in my eg coupe. I was on planning on a b18b swap but now i am receiving a b18a anyways
Here was what i bought so far:
94+ ls teg shift linkage
94+ Ls teg Wiring harness
5 mount and rubber from itr
I was wondering if i could still use these. I know the shift linkage will work. However, I am not sure if the wiring harness since the b18a is obd0 but my car is obd1. Distributor??ECU??Mounts...etc?? If you guy have done this or have the knowledge, tell your story. Help me out guys. Thanks in advance
Instead of a 90-91 b18a, Would it be better if i buy a 92-93 b18a so it will obd1 and won't have to worry wiring? HUmmm...imput?
Also i m going to get a hydro tranny so the cable hydro conversion is not needed
[Modified by ProJectCvic, 1:04 AM 3/20/2003]
[Modified by ProJectCvic, 1:46 AM 3/20/2003]
Re: B18a swap into EG Question (ProJectCvic)
Hey man i feel ya....i`m havin the same prob....i`m puttin a 93 LS motor in my 92 civic HB...i need to know what cv shafts to use...i have all access on this LS car so i can have anything i want!!i bought motor, trans, ecu, wiring harness, and anything else i want for 400 dollars...and it runs only a bad starter!!
Nate
Nate
Driver's side engine mount bracket and mount
Rear engine mount bracket
Front tranny mount bracket
A/C mount bracket for stabilizer or Del Sol VTEC bracket to reatin A/C
Stock or Integra upper tranny mount
Re: B18a swap into EG Question (VTECVillain)
HEy, thanks for the info VTECVillain....
It seem like i m getting a b18a from a 91 ls after all. I m getting a complete swap but i need to know what to change with the obd0 to a obd1 car issue. I think i need an obd1 distributor (but which one?). Do I need to change the injector like you said?? What else??...any info will be greatly appreciated!!!
Thanks in advance
I know that i have to use a 90-91 axles and immediate shaft, a pr4 ecu from a ls, 94+ls wiring harness and shift linkage from a 94+ (have a hydro tranny so don't need cable conversion kit)
Thanks in advance
You'll need an OBDI ECU, distributor and injectors. Reuse your stock harness or 94-95 LS if you already have one. There's no since in wasting $ on an LS harness since your stock one will work just the same.
You will want to use 94+ Integra axles and intermediate shaft since you are using the hydro tranny. The 90-93 parts will work but you need to change the tranny seal for the intermediate shaft to a 90-93 seal or it will leak and not fit correctly.
I know that i have to use a 90-91 axles and immediate shaft (have a hydro tranny so don't need cable conversion kit)
The injectors aren't an issue. It's just that the plug styles are different between OBDI and OBDII. I just said to use some OBDI injectors so you won't have to splice plugs.
Yes, if you use the 94+ intermediate shaft and axles you will be good to go.
I'd like to know about this too. I have a 95 cx and am putting in an ls motor from a 95ls. My friend totalled his gsr, so he bought an ls, and we're swapping the gsr into the ls, and the ls into my eg. I can take any part I need, but I believe all I will need is the mounts and linkage. Any wiring neccessary?
Re: B18a swap into EG Question (743)
You'll need to rewire to a 4 wire O2 sensor if you plan to use the LS ECU which I would.
It's a great day when your questions are answer with acutal answers not just "do some researchs" which I did. Thanks Villain.
Hey I have a obd1 car and am using an Ls ecu obd1 ecu and harness...does that mean that I have to change the injector into an obd1 b/c of fitting? The obdo b18a injector won't fit the wiring harness?
If that is that case than i believe my 93 civic dx injector will work..correct me if i m wrong
[Modified by ProJectCvic, 10:03 PM 3/25/2003]
[Modified by ProJectCvic, 10:06 PM 3/25/2003]
Re: B18a swap into EG Question (smokey2.0)
As long as you use an OBDI distributor, injectors and ECU, using the stock DX engine harness will make the swap plug and play with not additional wiring.
#18 pictured here?
or #26?
Re: B18a swap into EG Question (95hbMatt)
It's the #18 seal but for the opposite side of the gear box. That picture is the passenger side, you need the driver's side seal where the intermediate shaft goes in. They are probably the same seal for both sides but I would check before you buy.
THe wiring wont be as hard, but it will still take time.
plus with the 92-93 b18a you have more stock hp, like 10.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">You'll need an OBDI ECU, distributor and injectors. Reuse your stock harness or 94-95 LS if you already have one. There's no since in wasting $ on an LS harness since your stock one will work just the same.
I already bought the ls harnes so i m going to use it if i can...my loss
Ok, but i have another dilemma. I have a question about ECU setup. Can i use my stock civic dx ECU with the b18a swap with the ls wiring harness? Or should i use both the stock harness and reuse the stock ECU. I am using the obd1 injector and distributor. I am not sure about this? I believe i have to use a pr4 from a 94-95 LS integra but just wondering if the stock will work also.
Re: B18a swap into EG Question (IhateMy93BlackHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IhateMy93BlackHatch »</TD></TR><TR><TD CLASS="quote">Your stock ECU should work because your still using OBD1, but It would run better with the LS ECU</TD></TR></TABLE>
i would recomend that you run the pr4(or obd1 equivalent ecu), since this is the ecu designed to run this particular engine!
