::B20Z swap::: have questions!!
memoryFAB.com representative
ok.. i did a search.. i have a couple questions. will the throttle cable work for my car???(96 coupe) and the linkages i assume will work as well. looking into a new intake manifold... is the LS manifold the only one that will bolt up?? or will a B16a work?? and will an EX wiring harness work?? i believe it will. if there is any misc info i should know please fill me in. thanxx in advance!!
Re: ::B20Z swap::: have questions!! (spock_rocker)
throttle cable will work, you may need to vabricate a bracket.
linkages will not work
LS is the only manifold that will work
yes the ex harness will work, you will have 2 extra plugs because the b20 dosent have vtec, but it will work.
Re: ::B20Z swap::: have questions!! (Kamin)
what linkages will i need to buy?? i need all the help i can get.. and what about this bracket!! thanxx
GSR ones will work fine
and the stock bracket may be too short so you have to jb weld an extender on. it might work, it might not.
will B16a linkages work?? i have an LS manifold coming... is there anyother info i should know?? please anything would help. thanxx
yes LS (b18a/b) as well as JDM SMX b20b(low intake) will work. B16a/b18c5/b18c1 will work. another choice is to use a skunk2. yes EX wiring will work no problems. you'll need a hydro b-series tranny, mounts, shiftlinakge from 90-01 integra (b-series) or 99-00 Civic Si. as far as ECU use a 96-8 P75 or OBDI ECU such as OBDI PR4 or P75 (with harness converter)
Re: ::B20Z swap::: have questions!! (eg6ajk)
I dunno if your b20 came with an exhaust manifold but mine didnt... I used a b16 manifold and it bolted straight up to my cat I was soo happy haha.. btw i have a 2000 civic hatch ..
