does cel 23 retard timing ??
Old Mar 17, 2003 | 09:22 AM
type Gendy's Avatar
Default does cel 23 retard timing ??
I am getting the knock sensor code.... Its not wired up, had to get a new sensor and didnt install it yet. Would this CEL cause the car to adjust the timing or anything. I dont know if its related, but since i did the timing on my car, it has been backfiring after hitting vtec, and doesnt seem to run that strong up top.
Old Mar 17, 2003 | 07:46 PM
type Gendy's Avatar
Default Re: does cel 23 retard timing ?? (sick hatchem)
Great.....thanks for the info guys
Old Mar 17, 2003 | 07:53 PM
VTECVillain's Avatar
Yes it will cause the ECU to run in limp mode. Since the sensor isn't hooked up and working properly, it thinks that the car is knocking so it's going to do that until you get it fixed.
Old Mar 17, 2003 | 08:02 PM
poison's Avatar
Default Re: does cel 23 retard timing ?? (VTECVillain)
correcto!
Old Mar 17, 2003 | 08:21 PM
type Gendy's Avatar
Default Re: does cel 23 retard timing ?? (poison)
What exactly is limp mode?? IT retards the timing?? Does it also disable vtec?
Old Mar 17, 2003 | 08:22 PM
poison's Avatar
All extra services (VTEC, etc.) are disabled. Redline is lowered. Timing is retarded, and you are running rich.
Old Mar 18, 2003 | 06:30 AM
type Gendy's Avatar
I HAVE vtec however
Old Mar 18, 2003 | 12:42 PM
riceboy's Avatar
I've run a PR3 ECU on an LSVTEC, no knock sensor, threw cel 23 everywhere I went, never went into limp mode.
Old Mar 18, 2003 | 05:34 PM
type Gendy's Avatar
Default Re: does cel 23 retard timing ?? (riceboy)
Was there a noticeable difference in performance?? Like the timing being retarded or the car running richer?? Cause my car semes to be *******, and backfires, but still vtec.
Old Mar 18, 2003 | 09:17 PM
EF_LSVtec's Avatar
Same here...my tuner said that it will retard timing but not at full throttle.
Old Mar 19, 2003 | 11:11 AM
riceboy's Avatar
nope, ran great, until the head lifted.
jz2518
Jul 8, 2013 07:09 AM
Non Phixion
May 29, 2011 02:57 PM
TMTNG9
Aug 14, 2005 05:21 PM
AndyD
Aug 4, 2005 06:40 PM
fastwanabe
Jul 22, 2003 09:21 PM
