No Vtec in just finished swap!
Old 03-19-2003, 10:09 AM
DOHCarp's Avatar
Default No Vtec in just finished swap!
Alright I just finished a swap( 92 hatch cx with a b16a2 ) The problem is I am not hitting vtec.
I am useing a cx harness with a the vtec selonoid wired directly to the ECU. The only CEL I am getting is from the speed sensor and the O2....could either of these cause it to not craoss over to vtec. also I tried a stock p28 ecu and a chiped p28 with skunk 2 programming. any ideas guys...anything else I can check and double check. thanx.
[Modified by DOHCarp, 7:10 PM 3/19/2003]
Old 03-19-2003, 10:11 AM
delacampos's Avatar
Default Re: No Vtec in just finished swap! (DOHCarp)
did you run the vtec pressure sensor wire? did you ground the pressure sensor?
Old 03-19-2003, 10:17 AM
DOHCarp's Avatar
Default Re: No Vtec in just finished swap! (delacampos)
yup I ran a total of three wires.
1. Ground
2. vtec pressure sensor
3. vtec selonoid
am I missing anyhting?
Old 03-19-2003, 10:29 AM
delacampos's Avatar
thats correct. what are the exact code #'s you are getting? 41 and ???
Old 03-19-2003, 10:41 AM
Trey's Avatar
Vtec won't work without the speed sensor connected. Get the code 17 cleared and the Vtec will work.
Old 03-19-2003, 10:45 AM
2trix's Avatar
does your tach work!? do you have one? alot of times vtech will not be activated due to the ecu not knowing where your at on rpms...ecus are weird like that...have you tried to hook up your vss?
Old 03-19-2003, 12:00 PM
Trey's Avatar
Default Re: No Vtec in just finished swap! (2trix)
HUH??
The ecu always knows what RPM the motor is at. The guage isn't necessary. Ever heard of swapping a B swap in a car with no tach? The Vtec still works.......
Vtec looks at these variables:
Speed
Engine temp
Oil pressure
Old 03-19-2003, 12:40 PM
DOHCarp's Avatar
Default Re: No Vtec in just finished swap! (Trey)
thanks Trey...I'll give it a try as soon as I get home.
Old 03-19-2003, 12:44 PM
Kamin's Avatar
you have absolutley no idea what your talking about do you?
heres my vtec troubleshoot
https://honda-tech.com/zerothread?id=164863
good luck
[Modified by Kamin, 1:44 PM 3/19/2003]
Old 03-19-2003, 01:28 PM
2trix's Avatar
Default Re: No Vtec in just finished swap! (Kamin)
sorry guys!? what was i thinking....
Old 03-19-2003, 04:28 PM
DOHCarp's Avatar
Well the new speed sensor fixxed it...thanks again Trey!!!
Old 03-20-2003, 05:38 AM
DevinW's Avatar
Hope my engine troubles get fixed that easily..hehe
Old 03-20-2003, 11:40 AM
Trey's Avatar
No problem dood. Have fun and drive safe!
TristanW10
03-15-2010 03:33 PM
t-dizzy
05-18-2008 01:44 PM
Metal Head
33
10-09-2006 11:35 PM
ltho1998
08-21-2003 08:08 AM
Quick Reply: No Vtec in just finished swap!
