H22 EJ6 help
Old Mar 23, 2003 | 09:55 AM
junglerunna's Avatar
Default H22 EJ6 help
So my H22 is mounted in the my 99 coupe right now using HCP mounts. When I took out my D16Y7 I left that harness intact to the car, but I labeled everything on it. So would it be easier to use the DX harness or the H22 harness? Second the fuel filter is definatly going to be in the way when I try to put any type of intake piping on. Should I relocate it a little bit to the left some? I also cant seem to find out what to do with the power steering. The pulley is basically touching the headlight housing? So if anyone could help me out that would be great, and if anyone needs pics to help me I will take them.
Old Mar 23, 2003 | 01:41 PM
Default Re: H22 EJ6 help (junglerunna02)
ttt
Old Mar 23, 2003 | 08:38 PM
COMplex.'s Avatar
if you use the dx harness i'm pretty sure you have to add a few wires for vtec.
i've also been told that you have to use different injectors or rewire.
some peopledo move the filter to the left, but make sure you safely mount it.
and as for power steering, i havn't been given a straight answer either. its a tight fit i can tell you that.
i'm doing the swap within a month and i'm trying to get everything answered too...
hope i was a little help, maybe someone could help you out a little better.
luck to you
HEIGHTSR
Apr 15, 2010 05:44 PM
civichb97
Dec 9, 2002 01:22 PM
