will Obd2 injectors work with OBD1 ECU?
I am swaping a 97 b18c obd2 into an 88 crx si I am going to convert to OBD1 I am pretty sure the ditributor will work. (I have used OBD2 dzzy's on OBD1 cars)
but I need to knwo if the OBD2 injectors will work with the OBD1 ECU, as long as I take out the ressistor box. or should I just keep the resistor box, and use my stock crx si injectors? or I have some B18B obd1 injectors I could swap in? any ideas or recomendations?
thanks
thanks
