B20B or Z into 94 LS ???
is a straight up swap? anything special required to make it work? whats the difference between the B and Z and what kind of hp and tq does it make over the b18
thanks for the help in advance
Re: B20B or Z into 94 LS ??? (JeremyL)
it's a straight drop in. I think you have to use you b18 intake manifold. The b20 sits to high. The usdm b20 has 146hp and 133tq.
Re: B20B or Z into 94 LS ??? (eg6ajk)
nothing special. might need to swap the mount over, as well as the intake, (depends on the b20 you get)
Re: B20B or Z into 94 LS ??? (irev210)
dont forget to swap out the fuel pump or you will be running lean
shut up newbie
shut up newbie
Re: B20B or Z into 94 LS ??? (EKFerioHawaii)
shut up newbie
ouch...he got pimp slapped...
shut up newbie
I'm doing a b20b swap into my GSR right now (to tide me over while I build my 1.9L gsr) and it's pretty straight forward. I'm using my GSR wire harness, alternator, axles, drivers side mount, tranny, and PS system.
It's about as straightforward a swap as there is.
Re: B20B or Z into 94 LS ??? (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 »</TD></TR><TR><TD CLASS="quote">JDM B20B = Same engine as USDM B20Z. I think that theres like .2 diff in compression but hp and trq. are the same.
Blaze</TD></TR></TABLE>
depends on the year
if they aren't the same->there is a .8 difference in compression
horsepower is not the same
differen't redlines
different cams
different RPM's that peak tq appear at...
but yes, JDM B20B = USDM B20Z
mike
depends on the year
differen't redlines
different cams
mike
