having probelms with 99 b16a2 intoa 92 integra , need help!!
i used my stock integra engine harness and my cable tranny, i first used the si injectosr then tried my stock injectors on the b16 engine, it starts up then shuts rite off, im using the obd2 distrubuter , could that be the probelm??? i dont have a pr3 or pw0 ecu yet im just using the stock ecu in there for now, any suggestions would be greatly appreciated,
Re: having probelms with 99 b16a2 intoa 92 integra , need help!! (spoon063)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon063 »</TD></TR><TR><TD CLASS="quote"> im using the obd2 distrubuter , could that be the probelm???</TD></TR></TABLE>
Yes, you can use your b18a1 dizzy just cut the leg closest to the Vtec solenoid off. Did you cut the dizzy plugs off the obd 2 dizzy and use your obd 1 connectors? if that is the case, just redo the plug back to the LS dizzy and cut the leg off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon063 »</TD></TR><TR><TD CLASS="quote">i dont have a pr3 or pw0 ecu yet im just using the stock ecu in there for now, any suggestions would be greatly appreciated, </TD></TR></TABLE>
NO, you cant use those, they are OBD0, you need a OBD1 ECU (cause your car is OBD1), I would use a (in order of the best in my eyes) P28, P30, P72, or P61.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon063 »</TD></TR><TR><TD CLASS="quote">my cars obdo not obd1 , obd1 tegs started in 94</TD></TR></TABLE>
NO, believe me on this one
P61 : 92-93 OBD-1 Integra GSR
PR4 : 90-91 Integra LS/GS
Modified by turbogixxer at 1:12 PM 6/16/2003
Re: having probelms with 99 b16a2 intoa 92 integra , need help!! (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">
Correct. There is also a rare OBD1 PR3 as well.
