Please help me diagnose my bogging with my hybrid
Re: Please help me diagnose my bogging hybrid (J2turbo21)
what color is TPS suppose to be?
any other ideas, im gonna try my friends gsr throttle body with MAP and TPS sensors attached, to see how it runs.
bump.
bump.
Re: Please help me diagnose my bogging hybrid (Dominican_Kid)
check to see if you wired the O2 sensor, or try another one if the one you have is hooked up! good luck!
I`m having much of the same problem, I determined it to be fuel related(or lack thereof) so my next move is to install anew pump. That does`nt sound like your issue though since its a stock motor. No codes, huh?
i have a 96 dx and did a engine swap B16 first generation a year after i changed just my sparks plug NGK since then my car would start then later on shut off and now it wont start at all but i tryed changing the coil first that didnt start either i tryed chaning the module it sparked and start up but after reving for 5 minutes it cut off and never started up again i check engine came on but i tryed to get the code and it didnt show any code maybe its getting hot can it be my stock fuel pump maybe run 255 can u help me
imbrzyant
12-30-2007 07:10 PM
daredeezy619
02-09-2007 04:55 PM
LilRckt
02-21-2004 06:08 PM
