p30 ecu, its jdm right?
Re: p30 ecu, its jdm right? (absolut b18)
theres a usdm and a jdm. The jdm is refered to as a small box. So having said that the jdm p30 will be a lot smaller in size that then the usdm. Check out the pic.
http://pgmfi.crx-forum.org/res...M.jpg
Yup... small box is JDM, large/regular sized box is US. Only problem with the JDM P30 ECUs is that only the AUTO P30 can be chipped.... the 5-spd P30 can't be chipped (which is why I have like 3 extra ones that I can't sell ). The US P30 can also be chipped no problem.
Re: p30 ecu, its jdm right? (Newman)
So you are saying the JDM P30 manual cannot be chipped yes?
What about the P30J (from the civic SiR-II), same deal?
you should run a p73. All you need is to get a jumper harness from joe at hasport. It will allow you to connect an obd-2 ecu (p73) into your obd-1 car. the web site is locashracing.com its $258.00
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">Yup... small box is JDM, large/regular sized box is US. Only problem with the JDM P30 ECUs is that only the AUTO P30 can be chipped.... the 5-spd P30 can't be chipped (which is why I have like 3 extra ones that I can't sell ). The US P30 can also be chipped no problem.
really Newman? I never had any problems with reprogramming JDM MT P30 ecu's.
absolut b18,
The P30 ecu can be JDM or US. US version is regular size, JDM verson (already said) has a small type casing. If you need your JDM P30 ecu reprogrammed one day, hit me up I can reprogram any OBD1 P30 ecu (jdm or us).
Modified by Katman at 4:41 PM 6/20/2003
Modified by Katman at 4:42 PM 6/20/2003
absolut b18,
ivan93egreppin210
Engine Management and Tuning
10-11-2009 12:45 PM
