question bout sir 2 change over in a 92 hatch si
i purchased the complete change over from hondamotorsonline
do i need a mount kit or anything
also do i need to do anything for vtec since the car already has vtec
thanx for the help
thanx for the help
New User
Re: question bout sir 2 change over in a 92 hatch si (1stealthls)
Plug and play baby!
You have the stock SIR II axles, motor mounts, and GSR shift linkage right?
VTEC is already ready!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1stealthls »</TD></TR><TR><TD CLASS="quote">i got the sir2 linkages will those work</TD></TR></TABLE>
I'm not sure on the sir2 linkages but any 94-up integras linkages will work. also you only need to wire up the knock sensor: D3 pinout in the ecu
Re: question bout sir 2 change over in a 92 hatch si (sleeperciv)
WOW all plug and play. i did think there was something about using 3rd gen teg motor mounts, though. guess i'm wrong. some times it's good to be wrong.
Re: question bout sir 2 change over in a 92 hatch si (cccya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cccya »</TD></TR><TR><TD CLASS="quote">WOW all plug and play. i did think there was something about using 3rd gen teg motor mounts, though. guess i'm wrong. some times it's good to be wrong. </TD></TR></TABLE>
is this true?????
is this true?????
is this true?????</TD></TR></TABLE>
the only mounts I would use from the Gen3 teg is the driver side mount. people have been known to say to use the rear mount from the Gen3 too but I feel it's over kill.
Everything that came with your sir2 motor swap can be used in your SI.The mounts,linkage everything except the wiring harness which should be used to add to your stock harness.
Re: question bout sir 2 change over in a 92 hatch si (J2turbo21)
cool, so you don't need anything new. motor mounts that is. all the sir mounts will work in the SI.
so why would you use a 3rd gen motor mount then?????
If your motor didn't come with mounts then those are the easiest to find to install your motor. HMO sends it's swaps out with mounts.
Only thing like was said before is use your old Si harness, run a wire from the knock sensor to the ECU, and your good to go. Only thing not included in the swap is usually upper and lower radiatior hoses which can be bought from any auto parts store or Honda dealer. Just get ones from a 99-00 Civic Si.
Re: question bout sir 2 change over in a 92 hatch si (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">If your motor didn't come with mounts then those are the easiest to find to install your motor. HMO sends it's swaps out with mounts.
Only thing like was said before is use your old Si harness, run a wire from the knock sensor to the ECU, and your good to go. Only thing not included in the swap is usually upper and lower radiatior hoses which can be bought from any auto parts store or Honda dealer. Just get ones from a 99-00 Civic Si.</TD></TR></TABLE>
yep knock sensor wire. and my swap from HMO came with both radiator hoses that looked brand new(needed to buy new worm clamps because radiator neck is smaller than the B16's hoses)
Re: question bout sir 2 change over in a 92 hatch si (hatchdrvr)
so far the swap has went great today all i have to do is wire up the knock sensor.......where can i find out exactly where the d3 pin out is located will this bein a manual
89D15CRXDX
12
09-03-2007 07:16 AM
BeerBaron105
09-06-2004 02:39 PM
4-ageTOg63
12
05-26-2004 12:48 PM
Monty
10-04-2002 07:22 PM
