Why can't I keep my oil pan gasket from leaking?
Old 06-18-2003, 09:49 AM
Jonathan_ED3's Avatar
Default Why can't I keep my oil pan gasket from leaking?
No matter what I do, It keeps leaking around the lip.
I've gone through 3 gaskets now, two OEM and one offbrand, and it always does the same thing.
I've TQ'd them right, and in the correct sequence, but it just keeps leaking.
Does anybody have any tips? I've even tried gasket sealer, but it always starts a small leak along the backside of the block, and then starts slowly seeping out in other places as well.
Old 06-18-2003, 10:50 AM
junglerunna's Avatar
Default Re: Why can't I keep my oil pan gasket from leaking? (hot_EH)
Did you make sure you took old gasket off? Stupid question I know but I had to ask it. Whats the surface clean before you but the new gasket on. This is very strange also, because I never replaced this gasket on my h22 and yet Im not experiencing this problem.
Old 06-18-2003, 02:27 PM
NeMoo's Avatar
Is your oilpan straight? If you've banged it against a rock o something it might have gotten deformed. And have you tried Loctite-ing the bolts/nuts?
Old 06-18-2003, 03:14 PM
Default Re: Why can't I keep my oil pan gasket from leaking? (NeMoo)
surface is VERY clean.....didn't leave the old gasket on.
I've banged my oil pan....but it was leaking before I did that, so I don't think that's the problem.
It seems to me like the factory TQ specs just isn't enough to keep it from leaking with a rubber gasket.
I wish I could somehow use cork
I want to try to get the bolts a little harder on there, but I'm afraid of ruining something.
Old 06-18-2003, 07:02 PM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EH &raquo;</TD></TR><TR><TD CLASS="quote">It seems to me like the factory TQ specs just isn't enough to keep it from leaking with a rubber gasket.
if you tighten it anymore , it will get worse.
are you using Hondabond in the suggested locations when installing the gasket ?
Old 06-18-2003, 11:54 PM
OBD1 Kenobi's Avatar
Default Re: Why can't I keep my oil pan gasket from leaking? (Doctor CorteZ)
Clean off the surface of the pan and the gasket with brake cleaner. when you are confident that you have cleaned it completely, with clean hands, or best with latex gloves, squeeze and spread Permatex grey or copper sealant along the pan rim and gasket's opposite side. Once the oilpan is back on the block and the job is done, try to give it an hour or so to dry enough to hold back the oil.
Old 06-19-2003, 06:30 AM
Default Re: Why can't I keep my oil pan gasket from leaking? (OBD1 Kenobi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBD1 Kenobi &raquo;</TD></TR><TR><TD CLASS="quote">Clean off the surface of the pan and the gasket with brake cleaner. when you are confident that you have cleaned it completely, with clean hands, or best with latex gloves, squeeze and spread Permatex grey or copper sealant along the pan rim and gasket's opposite side. Once the oilpan is back on the block and the job is done, try to give it an hour or so to dry enough to hold back the oil.</TD></TR></TABLE>
This is exactly what I did the first time around! Maybe I'll give it another shot.
Is it possible I used TOO much of the sealer? How thick of a bead should I lay down?
Old 06-19-2003, 08:46 AM
Hybrid96EK's Avatar
It sounds to me like the pan is warped. Unless you have a pretty good eye and good metal working skills, it could be worthless at this point.
Old 06-19-2003, 09:38 AM
Si Integra's Avatar
I have the same problem..Except I have never banged the oil pan...never even scraped it. I tried using that permatex indian head stuff...that didn't even work..all the old shool mechanics say thats the best?
Old 06-19-2003, 09:39 AM
Hybrid96EK's Avatar
Default Re: (Si Integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Integra &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem..Except I have never banged the oil pan...never even scraped it. I tried using that permatex indian head stuff...that didn't even work..all the old shool mechanics say thats the best?
Its good stuff, yes. But it can't make up for a warped part. Once the part is warped you are pretty much up the creek. You don't even need to drop it to warp it. If you over tighten the bolts, it can warp easily also.
Old 06-19-2003, 09:47 AM
Default Re: (Hybrid93Eg)
how would I know if it's warped enough to not seal?
Brembomaster
Engine Machining & Assembly
07-02-2019 10:40 PM
Ostrich2.0
29
05-29-2014 02:14 PM
jdmspoonitr
11-27-2010 11:07 PM
hybrid_vtec
02-07-2005 06:53 AM
slow90si
08-15-2002 10:01 PM
Quick Reply: Why can't I keep my oil pan gasket from leaking?
