best swap for a budget
Old 06-17-2003, 02:01 PM
KRiS1's Avatar
Default best swap for a budget
Im going to try and squeeze a swap into my budget, what is the best bang for the buck swap for my 94 si. I need something reliable because im going to be putting alot of miles on it.
KRiS1's Avatar
Default Re: best swap for a budget (POS Hatchback)
Also if anyone can recommend a shop in So Cal
Old 06-17-2003, 06:48 PM
boostedgsrcivc's Avatar
best swap for the money is a b16a1 long block. then buy a tranny and ecu, ect. or just a b18a
Old 06-17-2003, 10:19 PM
mtber's Avatar
It depends on what body you are working with.
B18a or b - Crane cams & Nitrous or turbo & you are set.
B18c1 (GSR) - Type-r Cams & ValveTrain w/ type-r intake manifold & TB and a kenji p28 ecu & you are set. Maybe add a little spray
Old 06-18-2003, 10:55 AM
00MRSi's Avatar
Default Re: (mtber)
hmm.. What engine do you want? I'd be patient and save up enough for the swap I'd want. I'd go B18C1. Think about what your future plans/mods are for the motor. Good luck.
Old 06-18-2003, 11:04 AM
AMG
AMG's Avatar
Default Re: (00MRSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00MRSi &raquo;</TD></TR><TR><TD CLASS="quote">hmm.. What engine do you want? I'd be patient and save up enough for the swap I'd want. I'd go B18C1. Think about what your future plans/mods are for the motor. Good luck. </TD></TR></TABLE>
Perfect answer............plus you dont want to dump a fraction of your budget money for someone else to do it, here: Its a link that B18C5-EH2(TOM) made...very informative
https://honda-tech.com/zerothread?id=131949
This should help you save some money
Old 06-18-2003, 11:09 AM
New User
976's Avatar
Default Re: (dohcVTEChatch)
VTEC or non VTEC?
Old 06-18-2003, 11:10 AM
skribblah's Avatar
Default Re: (w00t!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w00t! &raquo;</TD></TR><TR><TD CLASS="quote">VTEC or non VTEC?</TD></TR></TABLE>
the allmighty expensave question...
Old 06-18-2003, 11:15 AM
This user can set his title.
ki3t's Avatar
What's your budget?
Old 06-18-2003, 11:16 AM
KRiS1's Avatar
Default Re: best swap for a budget (B18cR-EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18cR-EG &raquo;</TD></TR><TR><TD CLASS="quote">What's your budget?</TD></TR></TABLE>
Installed with everything around 5 grand
Old 06-18-2003, 11:27 AM
AMG
AMG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POS Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">
Installed with everything around 5 grand</TD></TR></TABLE>
With that, I would get the B18C, install it myself/with a friend, a save the extra money seeing as how things will more than likely need to be replaced other than just timing belt, water pump,and the stuff that you want to change before you do the swap.
Old 06-18-2003, 01:57 PM
New User
976's Avatar
Default Re: best swap for a budget (dohcVTEChatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTEChatch &raquo;</TD></TR><TR><TD CLASS="quote">
With that, I would get the B18C, install it myself/with a friend, a save the extra money seeing as how things will more than likely need to be replaced other than just timing belt, water pump,and the stuff that you want to change before you do the swap.</TD></TR></TABLE>
You'll save bling for sure...
Old 06-18-2003, 02:17 PM
b18-Hatch's Avatar
i think for the money, a ls swap is good. It all depends on what you are going for though. Some people live by b16's, myself personally, id rather have a ls motor.
ben
Old 06-18-2003, 04:16 PM
AMG
AMG's Avatar
Default Re: best swap for a budget (b18-Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18-Hatch &raquo;</TD></TR><TR><TD CLASS="quote">i think for the money, a ls swap is good. It all depends on what you are going for though. Some people live by b16's, myself personally, id rather have a ls motor.
ben</TD></TR></TABLE>
Very good point because if you do not have the money for a B18C and do not want a B16a, you can instead save alot of money and run the ls. Then in the future you can slap a vtec head and have the best of both worlds! Just better research and become knowledgable on those frankensteins because they can be tricky. But PLEASE do not tell me they are not reliable because unless you have experienced one or owned one personally, then you are just going off what every one else says. Just ask "For Hybrids" on here, his has been running strong for 2 years now I feel like i live by this remark, "Its all about choice"
Do the research then you decide
-Dylan
Old 06-18-2003, 08:17 PM
KRiS1's Avatar
well being that Im throwin a BIG chunk of change into buying a house later this year Ive narrowed it down to either a B16a or B18b, either one getting a decent rebuild
Old 06-19-2003, 09:46 AM
KRiS1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POS Hatchback &raquo;</TD></TR><TR><TD CLASS="quote">well being that Im throwin a BIG chunk of change into buying a house later this year Ive narrowed it down to either a B16a or B18b, either one getting a decent rebuild </TD></TR></TABLE>
ORRR should I skip the rebuilt motor and just pickup an ITR swap and call it a day?
Old 06-19-2003, 10:41 AM
Jonathan_ED3's Avatar
If you're going to be leaving it relatively stock...get a b18b over a b16. I LOVED mine.
But if you can afford it I'm gonna have to vote C5
Old 06-19-2003, 05:10 PM
Nikos's Avatar
these questions have been bothering me for ages....
How about the h22a?
H2B
01-09-2015 05:11 PM
Bert01
04-08-2012 04:21 PM
angrydyno619
11
04-10-2011 05:40 PM
runs11's
02-23-2005 07:59 PM
89JDMcrx
19
10-15-2002 07:53 PM
Quick Reply: best swap for a budget
