wireing an LS motor into my 91 dx
can i pull out my stock wireing harness to replace it with a 92-93 LS harness if i have the LS guage cluster,ecu, and motor? I thought it would be great if i could so the dpfi to mpfi would already be done, and everything would be plug and play right?
Re: wireing an LS motor into my 91 dx (4ghatch)
It would be hard. Just change your DX stuff where necessary to run the 1992-1993 motor and ECU. Trust me. It is MUCH easier that way.
Guest
Posts: n/a
Re: wireing an LS motor into my 91 dx (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">...It is MUCH easier that way.</TD></TR></TABLE>
In no way is it plug and play. You would need an entire under dash harness to have it plug and play. Removing your entire dash board isn't the easiest way to swap a motor. Make your life simple and stay OBD-0. And wire up for MPFI it's only eight wires and four are grounds.
Good Luck
Good Luck
