B18B into 97 Hx
I can has title
B18B into 97 Hx
I am getting ready to do a b18b swap into my civic. I have searched for a list of everything that I need to do the swap and to <U>keep it</U> OBD2 but I have found nothing. If anyone has done the swap before or could help me out that would be great. Thanks.
Corey
Corey
Re: B18B into 97 Hx (FabolusIconz)
Well first off, the easiest thing to do would be to get a 97-99 Integra B18B1 full swap. That way the engine would be your chassis year or newer not to mention everything will be OBDII and almost all plug and play.
You will need to reuse your stock harness on the motor and acquire a 99-00 Si driver mount bracket and rear bracket. Do some searches for EK motor swaps and you'll find the parts lists you need.
I can has title
Re: B18B into 97 Hx (VTECVillain)
The engine that I am in the process of buying is a 99 b18b with a 96 gsr tranny and type r clutch and flywheel. I was wondering if I would be able to use the stock shift linkage?
