gsr exhaust manifold ?
aight i'm currently in the process of swapping a gsr motor into my car and i wanted to transfer my apexi kit on my d to the b. my question is that if someone's done that on a b18b and it bolted up...will it bolt up just the same on a b18c?
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
Re: gsr exhaust manifold ? (leadtrum)
yes. if you are talking about just bolting to the motor and then mating to the cat...yes. now if the kit had a dp for gsr then you'd just have to lengthen the dp or car two inches. that's all. have fun swapping.
