I need a clutch alignment tool asap!!! In Dallas, TX
If anyone has a clutch alignment tool they can lend me I would appreciate it. I have a 99 b16a2 trans and a act clutch. I lost my alignment tool!!! 94 and up b series hydraulic trans alignment tool will work. Thanks.
Nick
Nick
Re: I need a clutch alignment tool asap!!! In Dallas, TX (b20ek)
I asked this same question when I was doing my swap, and people said 'use your finger'...I got mad because I didn't think you could...
But you really can just 'use your finger'.
Try it. All you have to do is get it in a good enough position to be able to slide the input shaft into it.
At the worst you'll have to try it a few times.
Re: I need a clutch alignment tool asap!!! In Dallas, TX (hot_EH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hot_EH »</TD></TR><TR><TD CLASS="quote">I asked this same question when I was doing my swap, and people said 'use your finger'...I got mad because I didn't think you could...
At the worst you'll have to try it a few times.</TD></TR></TABLE>
I remember this. That even pissed me off.
lol well dude if you really needed one THAT bad I would have just given you mine.
Really....now that you have the tool for sure, try it with your finger first. I bet you get it
you can use your tool set to align the cutch.
for example you will need 6 in 3/8" extension for a ratchet.
a socket that will completely fit into the pilot bearing on flywheel. (for my b18c it was 10mm 3/8")
then you will need a socket to fit/slide into the friction plate gears (for my b18c it was 17mm 1/2")
now what you do is first slide the 17mm 1/2" socket into the 6in 3/8" extension and then securely connect the 10mm to the extension. then tada!!! alignment tool.
note you might need different size sockets but i think all b series clutches and flywheel are the same.
you will know what i'm talking bout once you take apart the old clutch and flywheel.
jbrokos307
Mid-Atlantic (Sales)
11-02-2009 07:43 AM
Lbchronical
09-09-2009 09:12 AM
FourthGenHatch
04-16-2003 05:48 PM
