step by step instructions
Old Jun 10, 2003 | 10:49 PM
freakie's Avatar
Default step by step instructions
does anyone have step bystep instructions and pics if possible about swapping a h22a into the ek civic?
Old Jun 12, 2003 | 12:57 AM
freakie's Avatar
Default Re: step by step instructions (freakie)
anyone at all??? im too noobie to start on a project without one...
Old Jun 12, 2003 | 04:36 AM
Redsun's Avatar
There's a web site but can't remember the address. I have it saved in my favourites on my laptop but it's broke. Should have it repaired this weekend and i'll put up the link for you.
Old Jun 12, 2003 | 04:48 AM
SleeprCivic's Avatar
Default Re: (Redsun)
You've probably seen the Hasport guide, but its not exactly step by step. I don't know of any other.
Try writing a process of what you know and then ask members what you don't.
It would probably be close to the H22EG swap, so you could start there also.
Here's a start:
1 - remove old engine
3 - insert new engine
Ha, J/K man, good luck
Old Jun 12, 2003 | 05:50 PM
freakie's Avatar
thanks bud, ill wait til next week
Old Jun 12, 2003 | 07:53 PM
Rukusmasta2's Avatar
Default Re: (freakie)
you might wnat to contact poison he knows i got a manual form him once great info,
Old Jun 12, 2003 | 10:10 PM
freakie's Avatar
Default Re: (Rukusmasta2)
is the username just poison? Thanks for the heads up
Old Jun 15, 2003 | 09:20 AM
H22ACivic1's Avatar
i did a h22 in an ek. well i didnt do it but i had it done and was there the whole time.....motor mounts and wiring those are the biggest things. use the wiring harness from the civic. and buy an obd-2 - obd1 ecu harness. saves lots of time...if you put on an exhaust you'll need to weld in a test pipe to make it fit. h22 civics rock
Old Jun 15, 2003 | 09:33 AM
93civ2nv's Avatar
i need help picking a motor and doing the install.... like..... should i build up my 91 civic hatchback, or my 93 civic hatchback, and should i use the jdm b20b, or go with a jdm b16a1... i have already agreed to let jackson racing do the supercharging of the car to be different around here, everyone has turbo, no supercharged civic, so that is what i am definately going to do.... so any help with the car and motor choice to have a supercharged v-8 eater, is appreciated.... and anyone who has done any of these swaps with or the supercharger if you could email me some steps when you ahve time id appreciate that too.... send responses to iboidigitaLL@aol.com if you can please.
S u b Z e r o
Mar 11, 2014 02:56 AM
Four Dr R
Aug 15, 2010 09:44 AM
joechambers
Feb 4, 2010 11:26 AM
civic00_dude
Dec 23, 2005 12:57 AM
Ceune
Jan 19, 2004 10:53 AM
