can i re-wire an obd2 dizzy to run in an obd1 car??(searched_)
car=93 civic cx
swap=complete d16y8
question=i have a p28 ecu but am having a real hard time getting a obd1 sohc vtec dizzy. can i rewire my obd2 dizzy that came with my swap to work with obd1?? if so what do i need to do. thanks
swap=complete d16y8
Re: can i re-wire an obd2 dizzy to run in an obd1 car??(searched_) (mycvc8u2)
You can repin the plugs from the distributer to match with the harness, given that you still have the OBD1 distributer from the old motor. Just switch from the OBD2 (one plug) to the obd1 (2 plugs) by repinning them. If you are talking about something completely different, then I'm a retard, plus the hangover doesn't help.
Re: can i re-wire an obd2 dizzy to run in an obd1 car??(searched_) (JDMH22HATCH)
well i have the cx dizzy-can i use those plugs or do i need the vtec dizzy plugs or will the cx ones work?? thanks for the help-my hangover is killing me too-was my bday
Former Moderator
Why yes you can reiwre an OBD2 dizzy to work in an OBD1 car as someone else already said.
I had to do this with my fiancee's 1999 B16A2 swap into her 1992 Civic Si hatchback. We had to use her engine harness which supports the two-plug type dizzy, while the OBD2 B16A2 dizzy only came with one plug.
These pics will illustrate the MINOR changes you'll need to do in order to make it work for you.
First here is the OBD1 style two-plug engine harness intended for the two-plug OBD1 dizzy:
Next here is the OBD2-type dizzy plug:
Simply unpin and move the two bottom fat-*** wires in the one-plug OBD2 dizzy and add them to the "extra" plug that the OBD1 engine harness will have. The wires should even match in color.
Easy enough?
Easy enough?
Re: can i re-wire an obd2 dizzy to run in an obd1 car??(searched_) (B18C5-EH2)
I just swapped out the internals of the dizzy with my OBD-2 stuff, that way I have newer parts and no need to re-wire.
this was going from a 98 D16Y8 to a 95 B18B
Re: can i re-wire an obd2 dizzy to run in an obd1 car??(searched_) (Foozball26)
Yes, an OBDII distributer works fine with a 1992-1995 OBDI ECU (or vice versa). You just can;t mix and match 1988-1991 and 1992+ stuff.
Re: can i re-wire an obd2 dizzy to run in an obd1 car??(searched_) (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">Yes, an OBDII distributer works fine with a 1992-1995 OBDI ECU (or vice versa). You just can;t mix and match 1988-1991 and 1992+ stuff.</TD></TR></TABLE>
thanks matt
thanks matt
Former Moderator
Re: (nominous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nominous »</TD></TR><TR><TD CLASS="quote">What about converting a OBD0 to OBD1. Is that possible (I get the feeling that it cant be done, but to be sure...) ?</TD></TR></TABLE>
No.
The pulse rates for a pre-OBD distributor and the OBD1 distributor are totally different.
No.
Former Moderator
Re: (mattoien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattoien »</TD></TR><TR><TD CLASS="quote">How about an OBD1 complete swap into an OBD0 car? ('94 B18A into a '90 Integ LS)?</TD></TR></TABLE>
Feel free to start a separate topic - that's what this place is here for.
I just don't want any confusion in this topic.
mycvc8u2
06-14-2003 05:02 PM
mycvc8u2
06-13-2003 03:54 PM
