1st gen integra...
Old Jun 20, 2003 | 09:24 AM
servion's Avatar
Default 1st gen integra...
Can someone tell me what motor comes in a 1st gen integra? I'm getting confusing info in this one.... is it the d16a1? I know its twin-cam, non-vtec
I picked up a 89 standard hatch for 200 bucks, and I can get a 1stgen integra for $100... I was thinking of swapping the motor over.... Is it bolt-in? What about wiring?
Old Jun 20, 2003 | 11:19 AM
BIG RICH's Avatar
Default Re: 1st gen integra... (servion)
yes, it is the d16a1. what year integ. is it? 86-87 won't work. 88-89 will. you would have to convert your car from dual point fuel injec. to multi point. Your car now makes about 70hp, the integra motor makes some where around 115-118. Alot of people say it isn't worth. thats up to you. for a little bit more money($500-600) you could get a ZC with 135-137hp.
Old Jun 20, 2003 | 11:31 AM
servion's Avatar
Default Re: 1st gen integra... (BIG RICH)
What's the difference between the 85-87 and the 88-89 that would make it not work?
If I could get it to work, it would be a really cheap swap (100 bucks for the entire donor car), and it's still 45+ more hp than I have now.
Old Jun 20, 2003 | 04:25 PM
Katman's Avatar
I'm confused as to what your 89 std hatch is.
Did you buy a 89 CIVIC std hatch? or a 89 Integra?
if you bought an 89 civic....yer ASSED out. The D16A1 will NOT bolt into that car at all. In fact, none of the US 86-89 D16A1 engines will bolt into an EF chassis (EF=88-91 civic/crx chassis). You need to get an 89+ JDM DOHC ZC engine (black 8-bolt valve cover), which is specifically designed and will bolt into an EF chassis; and was not offered in the US at all.
The JDM ZC and US/D16A1 engines, internally are almost identical....some minor changes are higher compression pistons, cam lobe changes, intake manifold changes, and wiring/ecu changes.
However, if you have an 89 Integra, you CAN use the D16A1 engine you bought for $100. You would just need to swap all of the 89 integra's ignition parts over to the $100 D16A1 engine.
Old Jun 21, 2003 | 10:57 AM
servion's Avatar
Default Re: 1st gen integra... (Katman)
Sorry for the confusion... I bought the EF chassis, and I was inquiring about putting the motor from the integra into it. I was wondering if in fact the d16a1 is what comes in the integra.
Will what comes in that integra bolt into my ef chassis?
Old Jun 21, 2003 | 10:07 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Kat hit the nail on the head.
The 1986-1989 Integra motors fit much more easily in the 1985-1987 CR-X Si and 1986-1987 Civic Si hatches.
Old Jun 23, 2003 | 11:03 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for the confusion... I bought the EF chassis, and I was inquiring about putting the motor from the integra into it. I was wondering if in fact the d16a1 is what comes in the integra.
Will what comes in that integra bolt into my ef chassis?</TD></TR></TABLE>
nothing US-side as far as bolt-in w/oem mounts goes will bolt in from any year US integra. The only DOHC motor that will bolt-in, like i said, is a JDM DOHC ZC engine.
You can go B-series, but you'll have to buy a engine mount kit (HASport billet mount recomended).
Old Jun 23, 2003 | 11:40 AM
88LXi68's Avatar
you should check out http://www.g1teg.org
Joey.
Sep 9, 2006 07:37 PM
BlingBlingCivic
May 3, 2005 10:22 PM
FrankencrxBHAM
Nov 19, 2004 09:42 AM
eastcostJDMfanatic
Sep 12, 2003 07:45 PM
PaisanNYC
Mar 6, 2003 06:51 AM
