b20 in 96 hatch wireing questions
Anything I need to know? I am using a 96 civic automatic harness with a 98 Ls ecu. Just wondering if I would have to repin anything. I'm new to obd2!!
Re: b20 in 96 hatch wireing questions (mtber)
i also have a b20 swap in my 98 dx and i am having wiring issues
i attempted to repin the A14 to A12 and run the LS ecu I have and it makes the car run terrible. I have been using my DX ecu for the last month and it runs great...maybe a little lean but good otherwise.
btw I also used a plug from an LS harness to plug up to the IACV on my LS intake manifold and i paired up the two wires that matched and let the third one hang.
i mean it runs ok with the dx ecu...actually kind of quick, but when i put the integra ecu in it idles ok and when you put in gear and start driving there is nothing constant about the throttle. you take off then it stops then it peels out taking off again all while i am giving it a constant amount of throttle.
thats why i am still using the dx ecu
Re: (mtber)
oh forgot to mention i threw 6 different ecu codes so yeah it will take some time to solve it. i've fixed a few of the problems so i need to check and see how many codes i have now.
thanks for the info
thanks for the info
yea im putting a 97 b20 in my 97 hatchy pretty soon..as soon as i get the axles and a wire harness....cant find stock one....ok i was wondering if i can use the obd2 LS wire harness and use a obd2 ls ecu??
Re: b20 in 96 hatch wireing questions (b20ek)
Well this was originally my thread, its cool though. Can you use the rear mount bracket that comes with a 99 b20? I figured you could because its an "Ek" bracket and its shorter than the Ls bracket which is what I've been told you want. I've encountered some problems getting the engine in. Maybe its because I've been at it all day I don't know, but I'm using my B20 rear bracket so that's why I'm asking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">All you need to do is get a new idle air control valve plug and add it to your dx harness (2 plug end instead of 3 plug end)
eliminate the orange wire... Also repin your a14 to a12 at the ecu plug....
Oh yea thanks for that info it helped out alot. I was like what the hell this plug has no where to go and then it all made sense (plus I double checked the helms wiring diagram). Well thanks again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20ek »</TD></TR><TR><TD CLASS="quote">Well this was originally my thread, its cool though. Can you use the rear mount bracket that comes with a 99 b20? I figured you could because its an "Ek" bracket and its shorter than the Ls bracket which is what I've been told you want. I've encountered some problems getting the engine in. Maybe its because I've been at it all day I don't know, but I'm using my B20 rear bracket so that's why I'm asking. </TD></TR></TABLE>
i used a crv rear mount on my swap into a dx but it doesn't bolt up. i had to drill out one of the holes a little and i only have 2 bolts through it (3 holes in the mount). this is of course a temporary solution and i plan on putting the del sol mount, that is recommended, in when i replace my intake manifold because it will be easier to get to.
Re: b20 in 96 hatch wireing questions (moike)
damn mike, stop by and lemme look at it...
i thought that would have solved things for u...
Here is my wiring summary using the DX 96-98 harness on the b20...
CKF Sensor DX harness has 3 wires; CKF sensor on B20 uses two; Take plug from B harness and attach to D harness, match the two same colored wires and cap off the other (not used, ground) Black/Brown
Idle Air Control Valve (IACV) DX harness has three wires; B20 plug/sensor uses two. Match the two same colored wires and cap off the other black/brown wire. On the ECU Side move A14 (blue/black) to A12.
Intake Air Temp (IAT) Sensor Civics DX IAT with 99 Si Tube/Leave IAT on LS Manifold Plugged up OR use LS Intake tube with LS IAT on manifold, extend IAT harness to manifold.
EVAP purge solenoid valve Plug is different so just splice from one harness to the other, zip tie or mount to firewall.
MAP Sensor Extend to fit.
TPS Sensor Extend to fit.
Distributor B20 plug, match wires.
Primary O2 Sensor: Extend to fit.
Secondary O2 Sensor Extend to fit
[img]www.ablelimo.com/b20guy/a14_a12.jpg[/img]
Modified by b20guy at 10:27 PM 6/26/2003
Re: b20 in 96 hatch wireing questions (b20guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20guy »</TD></TR><TR><TD CLASS="quote">damn mike, stop by and lemme look at it...
Modified by b20guy at 10:27 PM 6/26/2003</TD></TR></TABLE>
You answered all my questions as far as wiring goes. Thanks!
i have a chilton book for eks and im looking at the schematic for a 96-98 D16Y7 and i cant find where the A12 wire is. Its not listed on the book. can someone help me too. THANKS
hondacurious
11-12-2013 01:14 AM
DB8 RHD
07-10-2011 04:13 PM
moike
03-14-2005 09:18 AM
