knock sensor
Old Jun 18, 2003 | 04:26 PM
Ivan's Avatar
senior gold member
Default knock sensor
what would be the best way to put a knock sensor on an lsvtec? its an obd1 block. it doesn't have a spot for it and I need it. Would the alternator bracket be a suitable spot? This is going in a 97 civic
edited for no more confusion
Modified by Ivan at 9:53 PM 6/18/2003
Modified by Ivan at 10:39 PM 6/18/2003
Old Jun 18, 2003 | 05:32 PM
poison's Avatar
Default Re: knock sensor (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">what would be the best way to put a knock sensor on a b18b? it doesn't have a spot for it and I need it. </TD></TR></TABLE>
What year B18B? If it's OBD1 then I don't believe they came with knock sensors and you won't be able to run one.
What's the reason you are in need for a knock sensor?
Old Jun 18, 2003 | 05:35 PM
Kamin's Avatar
Default Re: knock sensor (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">
What's the reason you are in need for a knock sensor?</TD></TR></TABLE>
yes, why?
they are pointless.
Old Jun 18, 2003 | 06:46 PM
Ivan's Avatar
senior gold member
Default Re: knock sensor (Kamin)
so I can run an itr ecu. I would use a chipped ecu but then I won't pass emissions cause they might hook up the scanner to it. Is it cool if I hook up the KS to the alternator bracket?
Old Jun 18, 2003 | 06:48 PM
Kamin's Avatar
more questions
ITR ecu with a b18b?!
WHY?!
yes you can dangle the KS off of somthing behind the engine but remember all the KS is, is a sensitive microhpone.
Old Jun 18, 2003 | 06:50 PM
Ivan's Avatar
senior gold member
hahaha sorry for not being more specific. its an lsvtec. I would rather run a chipped ecu but then I would fail emissions if they hook it up to the scanner.
Old Jun 18, 2003 | 06:51 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">so I can run an itr ecu. I would use a chipped ecu but then I won't pass emissions cause they might hook up the scanner to it. Is it cool if I hook up the KS to the alternator bracket?</TD></TR></TABLE>
I don't mean to sound like an *** or anything, but why are you running an ITR ECU on a B18B?
Not necessary.
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">hahaha sorry for not being more specific. its an lsvtec. I would rather run a chipped ecu but then I would fail emissions if they hook it up to the scanner.</TD></TR></TABLE>
ohhhhhhhhhh
haha i was like "wtf is this guy thinking!"
Old Jun 18, 2003 | 06:52 PM
Ivan's Avatar
senior gold member
Not necessary.</TD></TR></TABLE> that was my fault for not putting exactly what motor it was.
Old Jun 18, 2003 | 07:26 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote"> that was my fault for not putting exactly what motor it was.</TD></TR></TABLE>
ohhh ****.
I gotcha now. Good question.
Actually, OBD2 LS blocks have a knock sensor input, but unfortunately, OBD0 B18A and OBD1 B18Bs do not have a knock sensor input.
It would probably be easier to run an ITR chipped P28, or try and have the P73 chipped with the knock sensor removed.
Old Jun 18, 2003 | 07:38 PM
Ivan's Avatar
senior gold member
I thought obd2 ecus couldn't be chipped? its a jspec ecu. I would run the chipped ecu but then it wouldn't pass emissions. Here you pass if they hook up the scanner and you get no codes. with a jumper and obd1 ecu, you get no codes at all. atleast thats what happened with my p28.
Old Jun 18, 2003 | 07:40 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">I thought obd2 ecus couldn't be chipped? its a jspec ecu. I would run the chipped ecu but then it wouldn't pass emissions. Here you pass if they hook up the scanner and you get no codes. with a jumper and obd1 ecu, you get no codes at all. atleast thats what happened with my p28.</TD></TR></TABLE>
Hmm, that's the stickler here. You're correct with OBD2 ECU's not being able to be chipped.
I would probably just run the factory ECU then when you go to emissions. And run a chipped P28 everywhere else.
Old Jun 18, 2003 | 07:45 PM
Ivan's Avatar
senior gold member
yup thats the plan but I need to install the knock sensor so it can work with the itr ecu. can I just install it on the alternator bracket? will it be fine?
Old Jun 18, 2003 | 07:49 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">yup thats the plan but I need to install the knock sensor so it can work with the itr ecu. can I just install it on the alternator bracket? will it be fine?</TD></TR></TABLE>
You could, but I doubt it'll function. If you need the knock sensor badly,
I would just hook it up and probably JB Weld the sucker to the rear of the block.
The alternator bracket is an idea, but I don't know if it'll work.
Old Jun 18, 2003 | 07:55 PM
VTECVillain's Avatar
Check about half way down the page:
http://www.c-speedracing.com/h...c.php
Old Jun 18, 2003 | 08:00 PM
poison's Avatar
Default Re: knock sensor (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">Check about half way down the page:
http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
dayam! never saw that before.
great info bro
maomaniarocks
Nov 5, 2007 10:47 AM
integg93
Aug 3, 2006 01:17 PM
CaptivaBlue
23
Mar 1, 2005 03:19 AM
drewek-9
12
May 13, 2004 08:41 AM
Ivan
Jul 3, 2003 06:25 PM
