auto-manual conversion, hardlines?
This is for an EK.
How do you run the clutch hardlines? Is it just one single line that goes from the clutch master cylinder to the slave? Or how would I go about installing it?
(On an EG, I saw that the clutch lines go through a distribution block on the firewall *with the brake lines?* and runs somewhere into the firewall under the battery too.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 »</TD></TR><TR><TD CLASS="quote">I have the 96-00 Civic Helms, but how would I get the diagram loaded onto the computer without a scanner?
DOH!
How about drawing it? heh heh
</TD></TR></TABLE>DOH!
I did this swap for a customer, but on an EG. The hard line went across the firewall under brake lines and then under the battery tray and ran down the frame rail. It was a pita cause this was an ex with ABS....what a bitch. Hope this helps.
civicdriverzero1
Dec 9, 2006 09:23 AM
