B18c1 Civic help
Old Jun 17, 2003 | 08:01 AM
SleeperNine's Avatar
Default B18c1 Civic help
im planning on buying a b18c1 engine to put into my civic hb (92-95). im thinking of buying the engine from hmotorsonline.com and it comes with:
- Motor
- Hydrolic Tranny (S80, Y80)
- ECU (P72)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
i plan on getting the LSD tranny,
and also a custom exhaust
am i missing anything for the swap if i buy this??
Modified by SleeperNine at 2:39 AM 6/18/2003
Old Jun 17, 2003 | 06:10 PM
Lord Helmet's Avatar
Default Re: B18c1 Civic help (SleeperNine)
it's going to be a bolt on affair if you're concern about that. you just need to buy the normal maintenance parts: timing belt, water pump, cap & rotor, spark plugs, spark plug wires, teg upper & lower radiator hoses w/ thermostat, and heater hoses. hope that helps.
Old Jun 17, 2003 | 06:39 PM
boostedgsrcivc's Avatar
i hear hmotorsonline.com does a good job with the motors. i think jdmclub.com can get them for cheaper tho. might want to check them out.
Old Jun 18, 2003 | 10:21 AM
Default Re: (boostedgsrcivc)
alright thanks
96 hatch
Feb 22, 2007 10:43 AM
Lucid_Dream
39
Aug 17, 2006 08:56 AM
camp1984
Sep 3, 2003 07:19 PM
BLK99VTECR
Sep 2, 2003 12:28 PM
whiteJDMdc2
Jun 9, 2003 04:43 PM
