b16a is in and 100 miles later.......
BAM the car loses power and dies. Now the engine needs a tune up really bad but I dont think that is the problem. Car was running good considering it needs pugs and wires REALLY bad, and VTEC was pulling strong, no check engine light, no codes.
The timing belt was changed along with the water pump and a 8.8 lb flywheel.
I was going 65 in fifth gear and it stalled all of the sudden. I pull over and pop the hood and there is some smoke coming from under the hood, not much smoke though. When I try to start it, the motor cranks for a sec then a pop, pop, pop sound coming from the exhaust.
Any insight to what's wrong? I am going to change the plugs and wires now and see if that does anything.
The difference in power my car has or did last night, at least when the b16a was alive, compared to the stock motor is night and day. The car is a 91 STD civic so needless to say it's a world of difference going from 70 HP to 160. And I cant wait to drive it again.
Sorry for the long post
Re: b16a is in and 100 miles later....... (SiRWanabe)
Kinda sounds like u skiped a teeth or two on the timing belt. and as for the smoke posible burn off dirty hands leaving oil prints the heat buring them off.
same thing happened to me about a year ago in my crx si b16a,i towed it home took the entire engine apart and nothing was wrong with it after i gave up on possibilities that could of been i check the rotor in the distributor and the screw had fallen out causing it to misfire and not turn on lot of smoke came out too.check your dizzy could be it.
Lover
Re: b16a is in and 100 miles later....... (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">replace cap and rotor </TD></TR></TABLE>
plus where did you buy the engine from?
Re: b16a is in and 100 miles later....... (AK1200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK1200 »</TD></TR><TR><TD CLASS="quote">
plus where did you buy the engine from?</TD></TR></TABLE>
I got the motor from Hmotorsonline. The engine runs good I drove it around 100 miles then the distributor went. But Steve at Hmotors is replacing the dizzy, no questions asked.
shesinmyroom
36
04-10-2012 09:23 AM
southernSCHEME
10
09-29-2010 05:41 AM
tianporn
10
07-30-2004 11:49 PM
roadawg
31
08-21-2003 10:48 AM
