integra brakes on crx..possible?
Re: integra brakes on crx..possible? (ILOVEGIRLS)
Swap the knuckles (from 90-93 Integra) and change the upper A-arm for the front...... use the complete rear trailing arms (from 90-93 Integra) and use CRX Si e-brake cables (dunno if DA is too long.... didn't have a spare set to measure or test with).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILOVEGIRLS »</TD></TR><TR><TD CLASS="quote">thanks..can u do DC2 brakes?</TD></TR></TABLE>
You can, but the arms are different so if you use the CRX upper A-arm, you're going to have some wack camber (one guy I know did that.... I wish I took pictures of it - maybe 3+ degrees of neg camber at stock height). Unless you get the hub pressed out, and pressed onto your CRX arm, or just get a "big brake" kit, it's not going to just bolt right on and work perfectly.
ihateslowhondas
10-18-2004 06:46 PM
CRXTC
07-10-2004 06:45 AM
