axle snap ring
Old Aug 21, 2003 | 08:34 PM
User 5426's Avatar
Default axle snap ring
I have an h22a eg and have no clue what axles I have. The problem is that the passenger-side axle pops out and causes the whole car to shudder during acceleration. I heard that I can modify the snap ring to give the axle a tighter fit so it wont pop out. Anyone know of an easy way to accomplish this?
Would the axle poping out cause a leak of motor oil in a manual transmission? It has to be oil because there is no transmission fluid.
Old Aug 22, 2003 | 03:40 AM
92b16vx's Avatar
Default Re: axle snap ring (SeaQuake)
If the axle is popping out, then it is the wrong one. Not sure of the right one, click Raxles link in my sig. and send them an email, they know.
Old Aug 22, 2003 | 09:53 PM
User 5426's Avatar
Default Re: axle snap ring (92b16vx)
I shaped the snap ring like an oval and it seems to have remedied the problem. I am just sending "Thank you" IM's to all the people who gave me this idea.
Old Aug 23, 2003 | 10:36 AM
Newman's Avatar
New User
Expanding the snap ring will work... not the best remedy but effective. Just use needle-nose pliers and expand the snap ring a little bit more, and then put it back into the tranny. When you're putting the joint in, it should be really tough to get in, which is what you want, so just tap it in with a rubber mallet or with a 2x4 board until it's all the way in. The best thing to use is the 92+ Prelude inner joint on the Integra axle since the input shaft (with splines) on the joint is longer than the Integra one, so the snap ring will clip into the appropriate spot, where as with the Integra joint, it's just in there holding the joint in by just that, and not really "snapped" into place. But it'll still work, as I've done so on my old hatchback and had taken it to both the drag strip and road course w/out any problems.
Old Aug 23, 2003 | 12:34 PM
User 5426's Avatar
Default Re: axle snap ring (Newman)
Oh, I did look at the axle spindle and it did look kinda short. I was also thinking that It shouldn't shudder if it slightly came out. What is the disadvantage of using the 92+prelude inner joint on an integra axle ?
xXxHOLYMANxXx
Oct 17, 2011 10:07 AM
RanCRX
Dec 28, 2009 03:03 PM
Hyjnx
11
Feb 13, 2007 04:14 AM
stealthhatch
Mar 21, 2004 09:20 AM
User 5426
Aug 21, 2003 08:28 PM
