engine mount question pls help
Old Aug 18, 2003 | 08:05 AM
d15Beta's Avatar
Default engine mount question pls help
first of, how y'all doin?
hope all is good!
im planning to swap a b16a on my 94 EG hatch, im not sure wat gen. b16 i got but its a cable type, with pgmfi embosed on the intake and the code on the block starts with digit 1, my friends b16 sarts with 5,
so im sure mines the earlier gen.
my question is, regarding the mounts, could i use my stock civic eg mounts?
i heard that u could use the stock mounts, and use an integra rear tranny support or sumthin,
but then again, i heard from sum1 else that them stock eg civic mounts dont work?
could sum1 shed light on this? is it possible to use civic ek mounts? or are they just the same as eg mounts?
thnx for the help and feedback in advance!
Old Aug 18, 2003 | 09:33 AM
Audi RS4's Avatar
Lover
Default Re: engine mount question pls help (acid-burn)
you can bolt a B series engine on D series mounts but (A STUPID IDEA), and on an EG you need to get a GSR rear tranny mount.
Old Aug 18, 2003 | 10:46 AM
d15Beta's Avatar
ok bro
as u stated that u can use the d series mounts ( but a stupe idea?)
could you elaborate on that? wat r the pros and cons on using the d series mounts?
and also, if you know of sum 1 here on h-t that has a website that shows the complete diy swap of b16 to a eg hatch,
cuz i was checkin out the old post of tom(b18c5-eh2) and sum1 was sayin about makin up a website with this swap thingy,
stil havnt found a site though
but thanx a whole bunch man for even taking a look at my post, thanx for the insights!
peace!
Old Aug 25, 2003 | 05:50 PM
Audi RS4's Avatar
Lover
Default Re: (acid-burn)
https://honda-tech.com/zerothread?id=434523
or here
or here
https://honda-tech.com/zerothread?id=103937
hoped this helped somewhat, i run with an EK, so i have know idea about EG, except you can use d-series mounts on a b-series, it is not a good idea though.
revikan
19
Oct 1, 2012 06:56 AM
halfkoreanboy
Aug 8, 2010 10:37 AM
91DA9B16A
Jul 23, 2009 03:30 PM
ivan93egreppin210
Dec 14, 2008 04:27 PM
ridexstraight
Nov 19, 2004 10:21 AM
