just got the h22 started, first impression
Old Aug 24, 2003 | 09:45 PM
F120man's Avatar
New User
Default just got the h22 started, first impression
alright i just ght eh22eg running today, but i got some major problems/setback. im running a 93 cx h22a4 motor, with a B&M FPR, fidanza flywheel, act 6 puck, kenji p28 ecu(should i use this?) i dont have EGR hooked up, and currently there a code 21 check engine light on. im also using a gsr wire harness.
1. the car has SLOW/very sluggish acceleration, meaning that when them clutch starts to engage, the car's rpm goes up moderatly while at the same time the car doesnt move and feels really sluggish.(i can barely make it up a hill while crawling at 10-15 mph). and i can barely cruise around, i get around by driving around 20 mph.
2. what is code 21? how can i fix this?
3. the car is VERY hot, i cannot lift up the hood after about 10 minutes of driving. the frame around the motor is hot too, so hot that i cannot touch it at all. is this normal? because i think the motor is just really big and the engine bay is small.
4. the car is really loud as compared to the old b18c1 motor that was in the car. is this normal too?
ill have pictures up as soon as my car gets running.
Old Aug 25, 2003 | 07:33 AM
Jason kiDD's Avatar
Default Re: just got the h22 started, first impression (F120man)
If you have a chipped p28 make sure that its the right specs for the motor. If its for anything else then your engine will run sluggish especially at low RPMs because the injector pulses will be different..
Dunno what code 21 is but check a manual or book, maybe someone can chime in here. I am at work.
Same thing with me, the hood of my car gets hot and it sits not too far off the top of the engine, plus the headers generate alot of heat..
Prelude engine are way quieter than the b-series engines once they have a nice exhaust system. Did you have your full exhaust hooked up at the time? Open header it will sound like a raging lion..
Old Aug 25, 2003 | 07:57 AM
junglerunna's Avatar
Default Re: just got the h22 started, first impression (Jason kiDD)
Why are you using a GSR engine harness?
Old Aug 25, 2003 | 08:34 AM
F120man's Avatar
New User
Default Re: just got the h22 started, first impression (junglerunna02)
im using the gsr harness because thats what came with the car,(old b18c1 swap), i just used poison's guide and extended a few wires n such. as for the exhaust system, i got a full mandrel bent system from kteller8, welded onto the stock headers. im going to try to use my friend's p72 hopefully that'll make it run better. also, i dont have a resistor box for my injectors, is it neeeded at all?
Old Aug 26, 2003 | 09:40 AM
F120man's Avatar
New User
ttt
Old Aug 26, 2003 | 10:45 AM
Magnaflow's Avatar
[QUOTE=F120man]... i dont have EGR hooked up, and currently there a code 21 check engine light on... what is code 21? how can i fix this?
QUOTE]
Is it PO421?
Old Aug 26, 2003 | 11:13 AM
preluder's Avatar
Default Re: just got the h22 started, first impression (Magnaflow)
I think you just answered your own question.
Old Aug 26, 2003 | 03:11 PM
F120man's Avatar
New User
but what is code 21? is it EGR? i heard that egr wont run check engine light unless a p13 ecu was used.
Old Aug 28, 2003 | 08:58 AM
F120man's Avatar
New User
anyone?
Old Aug 28, 2003 | 10:29 AM
92b16vx's Avatar
EGR doesn't throw a code. 21 is the vtec soleniod valve, clear the code by resetting the ECU and then start it again and let it warm up and then drive it to see if the code comes back.
If it comes back check for continuity between P1 connector and the body, should be 14-30 ohms, if not then replace solenoid valve.
If so test for continuity between the A4 terminal on the ECU and the soleniod,no continuity = open in wire, fix it.
if there is test for it on the harness side between the P1 and body ground if there is continuity repair short between the A4 and the soleniod.
If not replace with known good ECU.
this is from the Helms, maybe someone has a easier way.
Old Aug 28, 2003 | 02:58 PM
fastwanabe's Avatar
Default Re: just got the h22 started, first impression (92b16vx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx &raquo;</TD></TR><TR><TD CLASS="quote"> EGR doesn't throw a code .</TD></TR></TABLE> if its a P13 it will throw a code.
Old Aug 28, 2003 | 10:43 PM
92b16vx's Avatar
Default Re: just got the h22 started, first impression (fastwanabe)
Yes, but in his post he stated he is running a chipped P28.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastwanabe &raquo;</TD></TR><TR><TD CLASS="quote"> if its a P13 it will throw a code.</TD></TR></TABLE>
squareone206
May 16, 2009 08:03 PM
glamXXXrock
Dec 17, 2006 02:35 PM
bardabe
Jul 20, 2006 05:38 PM
IOSUA
Aug 10, 2005 11:43 PM
angelgsrteg
Dec 28, 2004 05:29 AM
