JDM b16a into a 92 Civic two Intake Manifold sensor questions
Old 08-22-2003, 09:22 AM
DX Hybridizer's Avatar
Default JDM b16a into a 92 Civic two Intake Manifold sensor questions
Well ok this one has me baffled and none of my fellow hybrids are around for me to pick over there engine bays.
I have two identical two wire sensors one is a yel/blk and red/blk wire. And the other a yel/blk blue/yel ??? Sorry you guys should know wire sensors located at or near the intake manifold I have one sensor mount up point for these.
What do they go to? Anywone. Looking at my other hatch with a d16z6 I find there is a added think in the manifold on it.
Does one of these not get used on a JDM setup? Both motors I use to compare are OBD I
I also seem to have a spare tiny vacum line of the charcol canister that can't find a home that normally is on a little device on the back of the manifold. I know this all sounds confusing can anyone help?
Worse case I swing by a friends work and check tonight or take pictures to show tonight.
But the quicker help the better.
EDIT: Second thought do JDM b16's have a purge evap on them? Maybe that is what the vac and second sensor line is. I'm sorry guys I forgot all my research. And my helms are of course USDM.
Modified by DX Hybridizer at 1:55 PM 8/22/2003
3ndajdmb16a95
01-17-2013 06:04 AM
zaxfire69
05-19-2008 01:27 PM
tony n.
06-29-2005 09:28 PM
Morhpeous
06-11-2005 09:06 PM
orangecivic89
04-06-2005 06:43 PM
Quick Reply: JDM b16a into a 92 Civic two Intake Manifold sensor questions
