How do I remove pinout's from OBD2 wiring harness????
like the heading say's im kind of lost, on the OBD1 wiring harness's there is a PINGATE' and u just lift and remove....
on OBD2 there is nothing of that nature, how then do I remove the pin's? i tried just pulling and pushing with a small pick, but no luck. not even a budge. And I really do not feel like fixing a broken pin either.
Re: How do I remove pinout's from OBD2 wiring harness???? (Soon2B18Boost)
Ya, stick in the paper clip on the bottom part and it should slide out. There is a little locking part I believe too. It's hard to explain. Just look at it and there is a lil tiny plastic clamp in there holding in the pin. It'll slide out.
There is a piece of white plastic that you will have to pop out a little bit in order to get the pin out. Should be a white piece of plastic in the center of the plug that goes all the way around the whole plug.
typer 00-115
Audio / Security / Video
02-28-2003 05:38 PM
