will gsr heater hose fit? ( in cx hybrid)
Its that lower heater hose that snakes out from under the throttle body on the gsr engine. It came cut of course and the '94 cx hose won't plug in without a big kink. Will a full gsr hose reach the civic firewall location?
d
d
Re: will gsr heater hose fit? (daver)
i ran into the same problem with my friend's swap. we used the CX's heater hose from the heater core outlet, that is against the firewall, bought a seperate heater hose from the autoparts store and connected the two with a hose connector.
this option makes the hose long enough to prevent it from kinking up.
i'll try to post some pics later.
Re: will gsr heater hose fit? (Hatch4urSnatch)
a heater hose connector? I thought of that option, but i didn't know they existed. I'll have to look into that. I went and bought some 5/8" hose for 2 bucks. It won't bend like that gsr hose, so i would have to snake around like crazy.
d
d
i'm not sure if you have an autozone in your area but, that is where i purchased the hose connector in the picture.
xotic_crx
10
10-01-2013 04:08 PM
