removing axles?????
Old Aug 26, 2003 | 11:58 PM
daddymaxx's Avatar
Default removing axles?????
ok I snapped an axle at the track....
I I get home tonight and plan on removing the axle (driver side) and replace it with the brand new one I got. So I take teh wheel off, crack teh axke nut, remove the suspension fork, undo the upper ball joint, hammer the axle out of the knuckle. But I CANNOT GET THE AXLE OUT OF MY TRANNY. I mean I tried almost everything, is there a trick to this? I think I'm the only person to ever not get this out. I'm pretty sure it sligthly fell out at teh track, but I slammed it back in. Now I can't get it out! help!
Old Aug 27, 2003 | 04:54 AM
VTECVillain's Avatar
Default Re: removing axles????? (daddymaxx)
Pry between the axle and the tranny with a big flat head screwdriver or small pry bar as you turn the axle. It should pop out without much effort that way.
Old Aug 27, 2003 | 07:22 AM
daddymaxx's Avatar
it's on a JDM ITRM motor, so it has the intermediate shaft....
Old Aug 27, 2003 | 07:43 AM
monicle's Avatar
Default Re: (daddymaxx)
Might be easiest to take the entire intermediate shaft off first. Its a pain to get the axle off of the shaft. I had to use a hammer.
Old Aug 27, 2003 | 07:57 AM
Turbogixxer's Avatar
Default Re: (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle &raquo;</TD></TR><TR><TD CLASS="quote">Might be easiest to take the entire intermediate shaft off first. Its a pain to get the axle off of the shaft. I had to use a hammer.</TD></TR></TABLE>
Correct, thats what I do some time. It is a hole lot easy when it is out of the car.
flaxx0r
28
Dec 29, 2008 07:15 AM
bara6075
Oct 3, 2007 04:36 PM
jacoop86
Aug 11, 2006 04:07 PM
ill phil
May 15, 2003 06:27 PM
Pearce
Oct 16, 2002 10:44 AM
