bad synchros
Old Aug 21, 2003 | 08:36 AM
spooned out's Avatar
Default bad synchros
I think my synchros are bad it grinds in 4th and 5th gear if i really push on it but does not grind when driving it easy.. Some say it might be my clutch but it still grabs okay. i'm changing my clutch to exedy this weekend but can anyone tell me how i can check my synchros? whats involved in changing out synchros? or should i buy a new transmission to save some headache?
need info ASAP
Old Aug 21, 2003 | 11:43 AM
dankbudz11357's Avatar
Default Re: bad synchros (spooned out)
mine does the samething, grinds from 1-2 and 2-3 at higher rpms, i have to let it drop low and shift to get no grinds. really sucks, was told it's the synchros, thinking i might rebuild the tranny myself, or maybe just get it done by someone else. was told $450 for everything including a warranty.
Old Aug 21, 2003 | 02:46 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
syncros are bad/worn.
Old Aug 21, 2003 | 08:36 PM
how much is involved to changin synchros?
Old Aug 21, 2003 | 09:25 PM
Default Re: (spooned out)
get a helms manual. i just got a couple. but if you've never opened a tranny, then you can benefit greatly from this. very in depth and detailed. hope you find one. trannies aren't that hard to work on...sorta intimidating but you just have to dive into them and have the right tools. syncros are easy to swap out.
Old Aug 22, 2003 | 05:01 AM
976's Avatar
976
New User
Default Re: (not so civic)
Welcome to the club...
My third gear syncro is messed up. I might tear apart one of these days and change it. If you replace your clutch, you might as well get the work done on your tranny as well...
Old Aug 26, 2003 | 12:03 PM
ECKOTYPER's Avatar
I GRND THIRD AT HIGH RPMS NOTHIGN WHEN I DRIVE NORMAL SUCKS WHEN RCING THOUGH, LAST TIME AT THE TRACK I WAS HITTING 14.9'S CONSISTENTLY WITH JUST BOLT ONS IN MY GSR, I HIT A 14.903 AND I MISSED 4TH SO I HIT 14.903 A7 80 RATHER THEN THE OL 93.65 OR WHATEVA IT PIST ME OFF CAUSE I COULD OF PROBABLY HIT 14.8 OR 14.7 ON THAT ONE RUN
Old Aug 26, 2003 | 12:40 PM
poison's Avatar
Default Re: bad synchros (ECKOTYPER)
I'd recommend changing your tranny fluid and run Honda MTF. If it still grinds then I would replace the synchros.
Old Sep 7, 2003 | 11:19 AM
dominate9's Avatar
Default Re: bad synchros (poison)
Where can I buy synchros for my 97 Accord? About how much are they?
Old Sep 9, 2003 | 04:38 AM
crix180's Avatar
to make sure its your synchros i was told when you go to change you tranny oil see if there is any copper lookin shavings in there and if there is your synchros are bad.
Old Sep 9, 2003 | 06:27 AM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">I'd recommend changing your tranny fluid and run Honda MTF. If it still grinds then I would replace the synchros. </TD></TR></TABLE>
i was a believer in honda MTF until i read this thread: https://honda-tech.com/zerothread?id=549469
people are saying in there that they use honda MTF and still have grinds but when they switch to the GM stuff, the grinds usually disappear. maybe give that a try...its about the easiest fix if it works for your situation.
phoenixR
Dec 26, 2002 06:02 AM
01gizzer
Oct 4, 2002 09:30 PM
MrBite
Jun 13, 2002 12:48 PM
TypeSH
Apr 26, 2002 07:50 PM
Fr0m4311
Apr 7, 2002 09:31 PM
