H22 Tranny codes??
Old Aug 26, 2003 | 10:37 AM
Magnaflow's Avatar
Default H22 Tranny codes??
I searched and was unsuccessful. Anyone know where I can locate tranny codes? I am trying to find out this guy im talking to has an LSD tranny or not.
Code: M2U4-1000899
Any help would be appreciated, thanks!
Old Aug 26, 2003 | 11:19 AM
EKhothatch's Avatar
Default Re: H22 Tranny codes?? (Magnaflow)
Thats not an LSD tranny. M2B4 is the tranny code for LSD.
Old Aug 26, 2003 | 11:31 AM
Magnaflow's Avatar
Default Re: H22 Tranny codes?? (inline4hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inline4hatch &raquo;</TD></TR><TR><TD CLASS="quote">Thats not an LSD tranny. M2B4 is the tranny code for LSD.</TD></TR></TABLE>
Thanks!
Old Aug 26, 2003 | 12:38 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magnaflow &raquo;</TD></TR><TR><TD CLASS="quote">I searched and was unsuccessful. Anyone know where I can locate tranny codes? I am trying to find out this guy im talking to has an LSD tranny or not.
Code: M2U4-1000899
Any help would be appreciated, thanks!</TD></TR></TABLE>
Actually, there is a bunch load of H22 tranny codes. I would recommend taking out the axles, look inside the differential, if you see a bar it is NOT LSD, however, if you see it that it goes straight thru, then it does have LSD.
HTH.
Old Aug 26, 2003 | 02:19 PM
Magnaflow's Avatar
Default Re: H22 Tranny codes?? (poison)
the problem is, that I do not have access to see it. He is actually on EBay.
Old Aug 26, 2003 | 02:39 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magnaflow &raquo;</TD></TR><TR><TD CLASS="quote">the problem is, that I do not have access to see it. He is actually on EBay. </TD></TR></TABLE>
lol. tell that eBayer to get some pics of the differential before you buy it then
Old Aug 26, 2003 | 05:40 PM
Furry in your eye
Guest
Posts: n/a
according to my info that is a type SH tranny..... useless unless you have an SH prelude
Old Aug 27, 2003 | 08:24 AM
Magnaflow's Avatar
Default Re: H22 Tranny codes?? (Furry in your eye)
Hmmm, well Im mating it to an F20B motor, so I guess It will be useless to me, but I need a tranny so I may just go for it.
Old Aug 27, 2003 | 10:30 AM
Furry in your eye
Guest
Posts: n/a
the sh tranny has to have the atts unit on it to be of any use to anyone. if you need a tranny for the time being i have a h23 tranny i need to get rid of ...
Old Aug 27, 2003 | 10:39 AM
Magnaflow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furry in your eye &raquo;</TD></TR><TR><TD CLASS="quote">the sh tranny has to have the atts unit on it to be of any use to anyone. if you need a tranny for the time being i have a h23 tranny i need to get rid of ... </TD></TR></TABLE>
Well the Tranny was sold. But it wouldnt have worked at all? Would the H23 work with my flywheel I bought for an H22 tranny???
Old Aug 31, 2003 | 06:19 PM
Furry in your eye
Guest
Posts: n/a
the sh tranny wouldnt have worked b/c the atts unit wont bolt up to a normal h22 block, the sh block is different.
any f/h tranny except the SH trannys will bolt up fine, they all use the same clutch and flywheel
pr1mo_13
Dec 22, 2005 06:54 PM
j spec
Oct 6, 2005 05:25 PM
ricebox
Mar 29, 2004 08:56 AM
GumballNA
Jun 24, 2003 04:14 AM
